Sunshine Brakes
  • rickmc2000
    • Jun 2007
    • 45
    • Kennewick Wa
    Sunshine Brakes
    When my 78 XS11 sits out in the sun all day, the front brakes lock up and won't let go. I think its because the fluid gets hot and builds up pressure. Shouldn't there be a vent to keep thin from happening? Any suggestions?
    RickMc
    <ricks.mailbox@charter.net>
  • petejw
    • 2269
    • sydney australia
    hi rick,
    theres no vents in a hydraulic brake line,
    theres a small hole in the master cylinder than
    can block up, do a search for spooge hole and
    u should find a few threads about it.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • Stepka
      • Apr 2011
      • 170
      • Shakopee, MN
      Have you changed the fluid? Have you rebuilt the calipers?
      1981 xs1100 venturer... Finally runs
      Still has carb issues, but runs
      For all of your Amsoil needs go to www.mrguysoil.com
      • rickmc2000
        • Jun 2007
        • 45
        • Kennewick Wa
        Sunshine Brakes
        The article on cleaning the spooge hole seems to have worked. When I pulled the master cylinder apart, I found a real mess. Cleaned it out good and ran a small wire through the spooge, (it was plugged solid). And problem seems to be gone. Would still like to rebuild break calipers and master cylinder. Anyone know the best place to get rebuild kits?
        RickMc
        • petejw
          • 2269
          • sydney australia
          if the brakes are working ull probably find u wont need
          a kit as such, as long as the rubbers arent swollen or torn
          the parts can be cleaned up and put back together without
          any problems, use hot water to clean the parts and rubber grease
          or brake fluid on the seals when reassembling.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • rickmc2000
            • Jun 2007
            • 45
            • Kennewick Wa
            Sunshine Brakes
            Thanks for the info. Left front caliper is leaking a little bit. Could be form when the spooge was plugged and it build up pressure. Guess I'll know when I tear it apart. Was thinking it might be good to have new rubber just in case. Left front shock is leaking a bit also. Just got to take some time and giver her some TLC.
            RickMc
              • 9980
              Go here and refine your search to "brakes"
              Shop vintage Japanese motorcycle parts for Honda, Yamaha, Suzuki & Kawasaki. OEM and aftermarket parts trusted by builders for restoration and classic builds. In stock now.
              • redbone
                • Oct 2007
                • 244
                • Waynesboro pa
                i think georgefix on ebay sells the seal kit for the cals as well. they were pretty reasonable if i can recall.
                testing 1-2-3
                1980 1100 mns
                • New2Me
                  • Jun 2011
                  • 91
                  • Morris, IL.
                  I got my MS & Caliper kits from oldbikebarn.com last week and am happy with the results. I also bought stainless lines for $80 from this ebay person "coastguard1975" and am happy with them as well.
                  My rear brakes were hanging up even after I cleaned them. So I read up on here and it turns out that the brake lines tend to deteriorate and clog the system. Right now I'm waiting for a package from BikeBandit.com because I tore the slider boot when I was going threw the caliper. They are also sending me fork oil since one of them decided to start leaking all over my front brake this week.
                  -4:2 exhaust
                  -Pods
                  -Who knows what the future holds..
                  • tom clisham
                    • Sep 2010
                    • 627
                    • Northern Illinois
                    I got some kits from Georgefix on ebay. everything went fine. He has an excellent rep.
                    Tom Clisham
                    Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                    _____________________________________________
                    '78xs1100E ,all stock & original GONE TO WISCONSIN
                    '80 SG Vetter fairing,hard bags,trunk,fork brace,
                    stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                    79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                    79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
