Odd little key hole??
  • mrdigitech
    • Jun 2009
    • 87
    • Minneapolis, mn
    I noticed a key hole/lock type thing down by the middle drive/shaft the other day. It appears to have a wire or two coming from it.
    I have no idea what it is for. Any ideas??
    Thanks!!
    1979 XS 1100F
    Daily Rider
    DIY'r
    Minneapolis,mn
  • DCII
    • Jul 2010
    • 792
    • Centerville, Ohio
    Are you looking at the lock for the left side cover?
      That's the sometimes-missed locking latch for the sidecover (which is why broken sidecovers are out there...). Shouldn't be any wiring attached. They'll also get gummed-up and not work with the key, another reason for broken sidecovers...
      • mrdigitech
        • Jun 2009
        • 87
        • Minneapolis, mn
        could be
        I guess it could be the side cover latch. I've never seen any side covers for these 11's. So I don't know how they attach. There is the key lock right under the seat (helmet lock i believe).
        Then there is this smaller one way down right by the shaft/middle drive attached to the frame on the left side. I'm at work so I cant verify there are wires but I thought there was.
        1979 XS 1100F
        Daily Rider
        DIY'r
        Minneapolis,mn
          Yes, there are wires there. That's the main chassis ground strap. Be sure both ends of that wire are clean and corrosion-free. Dab a bit of anti-sieze on both ends to prevent corrosion and assist in electrical flow.
          • jwhughes3
            • 2798
            • Home of the Alamo
            supercharger
            Thats the key operated supercharger - just turn the key clockwise (or is it counter-clockwise?) just before you ride for an extra burst of speed!
            John
            '81 XS1100H - "Enterprise"
