middle gear case
  • middle gear case
    Anyone have an exploded view of the middle gear unit. I'm trying to remove the spacer right behind the cover on the left side and can't figure out if I need to pull the bearing etc to get it off.
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    '79 XS11 Special
    MikeXS Pods
    Green Coils
      U can look up exploded views of the whole bike here.
      '79 XS11 Special
      MikeXS Pods
      Green Coils
        Curious why you are messing with that shim? Middle drives are still pretty cheap to get.
        79SF
        XJ11
        78E
          Ahh, Grasshopper, when the drives are scarce, he who knows how to repair them will be king.
          (If I can mix some genres.)
          For the record, one gallon paint cans are about 10 thou thick, aluminum beer cans are about 5, except Coors, which is a bit thinner. All, of course, subject to your mike. CZ
            Nope
            The one on the LH is pretty banged up. Going to repaint the cover and wanted to remove and paint the shim at the same time to match. Seems to me it should just pop off but I had trouble removing the bolts. When I looked in the holes there was a lot of adhesive binding the threads. Figure this thing is glued on similar to the final drive/ shaft joint, rather than with a gasket. Not sure if I can get it off. May be a rattle can application will be required on that piece.
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              I think you mean the bearing housing #3 in the posted pic. Dont think its advisable to remove it in place. Again Catbug comes thru and has a manual on this for download at his site if you want to view it.
              http://www.ringler.us/family/mybike.html Shaft drive service manual.
              79SF
              XJ11
              78E
