Anyone have an exploded view of the middle gear unit. I'm trying to remove the spacer right behind the cover on the left side and can't figure out if I need to pull the bearing etc to get it off.
middle gear case
middle gear case
mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Tags: None -
Curious why you are messing with that shim? Middle drives are still pretty cheap to get.79SF
XJ11
78EComment
Ahh, Grasshopper, when the drives are scarce, he who knows how to repair them will be king.
(If I can mix some genres.
For the record, one gallon paint cans are about 10 thou thick, aluminum beer cans are about 5, except Coors, which is a bit thinner. All, of course, subject to your mike.
CZ
Nope
The one on the LH is pretty banged up. Going to repaint the cover and wanted to remove and paint the shim at the same time to match. Seems to me it should just pop off but I had trouble removing the bolts. When I looked in the holes there was a lot of adhesive binding the threads. Figure this thing is glued on similar to the final drive/ shaft joint, rather than with a gasket. Not sure if I can get it off. May be a rattle can application will be required on that piece.mack
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
613-398-6186Comment
I think you mean the bearing housing #3 in the posted pic. Dont think its advisable to remove it in place. Again Catbug comes thru and has a manual on this for download at his site if you want to view it.
http://www.ringler.us/family/mybike.html Shaft drive service manual.Last edited by SFerinTEXAS; 06-28-2011, 08:14 AM.79SF
XJ11
78EComment
