Oil rings au go go
  • KA1J
    • 664
    • Groton, CT
    Oil rings au go go
    I'm likely to have the rings going back in the pistons tomorrow & wonder about the corrugated oil ring. Do I have to do anything with it other than sandwich it in between the thinner two rings? Is there any overlap of the corrugations I have to do, or do the ends simply butt together while I'm inserting the pistons in the cylinders.
    And, is there any preferred direction the gap in the rings is oriented towards?
    Thanks.
    The ends of the oil ring expander/spacer just butt together with no overlap above the right-hand end of the piston wrist pin.
    There is a picture on page 3-44 in the PDF version of the Yamaha shop manual that shows the piston ring positions.
    Looking down at the top of the piston with the forward-facing edge of the piston at 12 o'clock:
    Top compression ring gap: 11 o'clock
    Second compression ring gap: 5 o'clock
    Oil rail expander/spacer end gap: 3 o'clock
    Upper oil rail gap: 7 o'clock
    Lower oil rail gap: 1 o'clock
    • KA1J
      • 664
      • Groton, CT
      Wonderful! Thanks for the pointers.
      • Lamric
        XStremely XSive(Deceased)
        • 410
        • Kenley, Surrey, England
        Brian
        XS1100 LG "Mr T", SG "ICBM" & FJ1200
        Check out the XS Part Number Finder
        Be not stingy in what costs nothing as courtesy, counsel and countenance.
