handlebar options
  • PlanetMobius
    • May 2011
    • 15
    • Waukesha, Wisconsin
    handlebar options
    The swept back bars on my 80 special are a bit uncomfortable for me. They don't seem to be that conducive for handling and I want something more forward and perpendicular to the bike. For those of you that have swapped bars, what have you found to be better. Also, I've noticed that the master cylinder for the front brake is configured in such a way that the reservoir is held level on the original bars. If I opt for straight bars, this will be canted towards the center of the bike. Does this create any problems?
    Could switch to a standards bars and master cylinder. Easy swap and much better riding position.
      • 9980
      Personally I like the buckhorns, but Nate is right about the standard bars as far as a change in the direction you want to go. My bike had standard bars with the Special MC when I got it and there didn't seem to be a problem.
      Some have switched to Honda CB750 bars or Goldwing bars to accomodate their comfort zones.
        Originally posted by BA80
        ..My bike had standard bars with the Special MC when I got it and there didn't seem to be a problem..
        Running the master cylinder at an angle won't hurt a thing; Harley has been using the same master on all their bikes for years, regardless of handlebar type, with no problems.
        It does make checking/adding brake fluid a bit of a PITA, but just loosen the bar clamps and move the bars, then move 'em back when done...
          Hi Mobi,
          others think differently but IMHO the best use of the rototiller bars is as part of a windchime.
          But which alternative bar will fit YOU? Not necessarily the one that fits me, right?
          What to do, what to do?
          Go to a bike dealer's rack of bars or go to a bike swapmeet (every swapmeet I've ever been to has at least one vendor's table with a box of bars underneath, usually at $20 a pop.) Pick up a bar and hold it up in a riding position to see if you like it.
          And as has been said, a slanted M/C will work just fine although it could take some extra effort to add fluid without spilling any.
          • petejw
            • 2269
            • sydney australia
            ive got my mc at an angle after swapping the bars
            with out any problems, having the handle bars at full lock
            to the left and the m/c sits evenly to top up.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • PlanetMobius
              • May 2011
              • 15
              Thanks guys,
              that's a lot of stuff I did not know.
              • tonyg-5386
                • Aug 2010
                • 25
                Handlebar Options
                I have a 79 Special that had stock bars. Horrible!!! I rode my friends Honda cb900 Custom and thought the bars were great so I went to the Flanders website and ordered their replicas of the cb900 custom bars. They've been on the bike for 10 yers, never rusted and was probably the best and easiest mod I ever did to the bike.
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  angle OK
                  I have switched to CB750 bars from MikesXS - the MC was at a crazy angle but as long as its tight and not leaking seemed no worse for the wear - I have since replaced it for other reasons but fear not - see if you can sit on the bike and have someone measure where your hands are when in a comfy position and use that to find your bars -you might duct tape a hanger wire to the base of existing bars and bend till hands are perfect and measure the ends from there.
                  John
                  '81 XS1100H - "Enterprise"
                  • xs11lover
                    • 1433
                    • Montoursville Pa
                    I have cb750 bars on the special now. I like them alot. They aren't as funky as the stock buckhorns. I use to have clubman bars on the old bike. I loved the way they looked but they were very low and I'm sure not for everybody.
                    79 XS11 Special (Lazarus)
                    79 DT 100
                    • debauchery
                      • Jul 2007
                      • 47
                      • Southeast Massachusetts
                      don't forget about ape's , and you can add a ss brakeline going to the dist block for some bling! i find them very comfy as i do not nd to arch my spine like quazimoto to get around .
                      this thread bring up memories of when i first purchased my xs it had stock special bars on it , so i've ridden 20-30 different bikes and i climb on the xs excited about the jet/cam work this guy claims shes had done , start it up and had the most akward time muscling the machine to point towards the road few mins later i'm trolling home and found a straight piece of road to stretch my wrist this resulted in my ass sliding onto the passanger seat and barely holding the bars with a fingernail or two
                      if you goosed a bike with the stock special bars = she takes off like a rocket and she doesn't care if you come with her .
                      i went home and imedietly took the cage to buy some big ol apes and now no matter how hard i snap it i KNOW i'm going with the bike be it for better or worse...
                      79 xs eleven special
                      pods
                      jetted
                      cammed
                      pitted chrome
                      straight pipes
                      16" apes
                      +6 front
                      -2.6 rigid rear (still regret this)
                      blinkers are for slow ppl
                      http://i473.photobucket.com/albums/r...1/100_3355.jpg http://i473.photobucket.com/albums/r...1st2011021.jpg
                      "here for a good time NOT a long time"
                      • jwhughes3
                        • 2798
                        • Home of the Alamo
                        cb750
                        garrett - my supposed cb750 bars from MikesXS do not look anything like yours..
                        mine look like this:
                        http://www.mikesxs.net/products-58.html#products
                        part 25-1083 down the page.
                        They have some similar to yours called clubman - was that a type of CB configuration or a style of bike like a cafe racer?
                        John
                        • xs11lover
                          • 1433
                          • Montoursville Pa
                          No, no no the pic is of the clubman bars, I have not taken any pics of the new/old bike yet.
                          79 DT 100
                          • tom clisham
                            • Sep 2010
                            • 627
                            • Northern Illinois
                            I'm with BA80. I really like the buckhorns. probably depends on the legnth of your arms, your ht, your wt, you get the picture.
                            I do have a set of standard bars in case I change my mind.
                            you can mount just about any 1&7/8 in bars on these.
                            Ebay has all different shapes & sizes for as low as $20-25 brand new.
                            Tom Clisham
                            Age is relative YOU WON"T GET OLD TIL YOU SELL THE BIKE
                            _____________________________________________
                            '78xs1100E ,all stock & original GONE TO WISCONSIN
                            '80 SG Vetter fairing,hard bags,trunk,fork brace,
                            stock headers with fishtail mufflers,black & beautiful GONE TO ARIZONA
                            79SF lowered,jardine 4/2 exhaust,pod filters,drilled rotors,fork brace, bar hopper
                            79SF 1 owner,8000 miles, restoring to completely original ( I hope) GONE TO FRANCE
                            • g15usmc
                              • Nov 2010
                              • 365
                              • 29 Palms CA
                              I put Protapers on my 79 special...They are the contours which needed a 7/8 to 1 inch conversion for the mounting of the bars, but the actual ends are still 7/8 so you dont need to change any controls, i inverted them to make for a more aggressive stance however, I had put them on the right way and they fit nicely as well...the mounts i installed also added about a half inch of height to the risers and that made them very comfortable...bothways...heres a few pics...
                              Daily Driver - '04 Suzuki Marauder 1600
                              Project Bike - '79 XS1100 Special
                              Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
                              Ride Till You Die!
                              "MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
                              “Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
                              "When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"
