Install an Off-The-Shelf Headlight in a Standard..
    One issue with the standard square headlight is as-sold, you can only use a Yamaha replacement, which as we all know are difficult to find sometimes and usually expensive. I suggested this to DaVinci, but was at a boneyard yesterday so I picked up a car/truck headlight bucket assembly to see if this was feasible... well, it is.
    Here's the how-to and if all you have is the bucket and trim ring, I'll give dimensions so you don't even need a OEM light for a pattern...
    [IMG][/IMG]
    Here's the comparison between a OEM and automotive-type bucket. In this case, this one is off a '80s S-10, but there's plenty of other vehicles that used these and they'll all work as long as the trim/retaining ring is rounded like this one. Cost me all of $7....
    [IMG][/IMG]
    Cut off the original adjusting/mounting ears.
    [IMG][/IMG]
    The next several pics are all related. In this one, this is how you locate the mounting points. Using a square against the top and left edges (looking from the back), the center of the main mount is 4.5" over from the left end. The top aiming screw is 1.5" in, or 3" from the center hole. The lower adjusting screw is opposite the top center hole.
    [IMG][/IMG]
    Main mount fabbed and installed. The top of this should be between 1/32" and 1/16" higher than the headlight retaining ring, or in this case, 1/4" above the bucket. I'll note here that the two adjusting brackets should have their hole centers even with the retaining ring also. I'll also note that the main mount I made out of some scrap body sheetmetal, but I used some stouter .062 thick material for the adjusting brackets so they won't bend.
    [IMG][/IMG]
    The upper adjusting bracket. The 'tab' with the hole in it should be .4" (13/32") on it's inside length after bending. Bend it to 90 degrees, then go another 15 for the correct angle, and do the same for the lower bracket. By the way, all the screw holes are 3/16".
    [IMG][/IMG]
    I drilled a 7/16" hole through the bucket for a nut. I'm using a 10/32 screw and nylock nut for the main mount. You'll need to lay the nut in there loose, then install the light. You'll be able to hold the nut with some needle-nose pliers when assembling. Note that the screw cannot be any longer than 3/8" or it will contact the light. Also note that I did the pop rivets from inside shell for the same reason; it's tight in there...
    [IMG][/IMG]
    This pic is important; to properly locate the headlight, the center of the mounting should be exactly 1.125" from the front edge of the retaining ring.
    [IMG][/IMG]
    Same thing goes for the adjusting tabs, although you have a little wiggle room here...
    [IMG][/IMG]
    This shows the finished top mounts, but also shows that I had to bend the two top retaining ring tabs back for clearance; the bottom ones should be OK.
    [IMG][/IMG]
    Installed headlight... looks factory...
    [IMG][/IMG]
    Final modified parts. I cut the excess back out of the bucket (that was harder than all the rest!) for a bit more room, but you may not need to.
    If you don't have any of the OEM hardware, you'll need one 10/32 x 3/8" screw, one 10/32 nyloc nut (I don't see any way to get a lockwasher in there) for the main mount, and two 8/32 x 2.25" screws, two 8/32 square nuts, and two .25" OD x 2" long springs. You may be able to find the springs at the wrecking yard, look around.
    You can now use any standard 5x7 automotive headlight, or any aftermarket replacement like a Cibie or Hella. No more hunting for a good OEM unit...
    That's it unless there's any questions...
    • 8892
    Leave it to you Steve, coming up with that, nice job.
    • DAVINCI
      • Jan 2011
      • 1048
      • Cedar Mountain, NC
      Great work, Steve! Looks exactly like the pictures in my head! Very detailed explanation, too.
      Next time I drop my light and break it, this mod is on my list.
        • 5073
        I did nearly exactly what you did, but with mine, the headlight was a little cock-eyed in the housing because I am not as good as you in the measurements. I ended up buying a later model housing and lens and just sed an h4 bulb. Plug and play.
        • jwhughes3
          • 2798
          • Home of the Alamo
          looks like a great mod!
          Steve thanks for taking time to document along the way...
          one request though - don't channel any more pics from DAVINCI's head - I'm afraid of what we might see
          seriously - this mod needs a page on the permanent tips.
          John
          '81 XS1100H - "Enterprise"
            Thanks guys... I've been wanting to put a Cibie light in my standard for years, this will let me. The parts won't go to waste...
              I want to see some comparison shots of the OEM lenses compaired to the cibie lens. Once I get things finished I will be driving it in the dark frequently when coming home from work so I want to see what the difference is and if it is worth the $$
                Nate, I've installed Cibie lights in numerous vehicles over the years, and they've never failed to give me an improvement over what I had before, even when replacing a H4 halogen light. They use optical-quality glass for better light transmission, their lens designs are first-rate, and the best part is you can get this in a legal package, not some hashed HID conversion or oversized lamp that will burn up your wiring. If I'm buying an hi-performance aftermarket light, it's my first and only choice...
                Here's a link; scroll down for the square lights...http://www.danielsternlighting.com/p.../products.html
                  • 3951
                  Steve- Is this mod necessary if I want to use a different headlight, and my housing is the '79?
                    Yes. If you want to use anything other than a OEM Yamaha sealed beam (which are difficult to find and expensive if you do find them, plus the light output suck in comparison to new bulbs).
                    There are some old yamaha replaceable halogen H4 bulb conversions but they too are rare and expensive.
                      The '78E (US version) used a 'sealed beam' with a non-replaceable lamp. All other models and the '79-81 US version used a replaceable H4 type lamp. The sealed beam shows up used or as NOS parts regularly as nobody really wants one. The big problem with the OEM H4 lens assemblies is they had inferior sealing and the reflector silvering goes bad over time from moisture, so good units are very hard to find... and more $$ than a Cibie conversion when you can find them.
                        I thought they all had the sealed bean and the replaceable lamp was offered later. Not quite as rare then I guess!
                          They're still rare as so many have gone bad....
                          The sealed beam was the only one that was sealed good enough to maintain it's silvering over the years so you'll find those installed in the later bikes when the owners couldn't find a good H4 lens.
                          I've got 3-4 of the H4 lenses around here, but I've only got one that's good enough to where I'd use it and that one is marginal....
                            • 3951
                            So, if I bought an LED headlight like "The Rev", I would have to abide by this mod, no alternatives? It won't just drop-in the bucket?
                              Nope.......
