If you're in there, replace the friction plates anyway. Also replace the clutch release bearing. Well worth doing
Clutch slip?
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model. -
You could replace the friction plates but you might want to measure them first. Very rarely do I hear of them being below specs.
The bearing might be a good idea, however, I have only heard of one of those ever going bad. It was destroyed by someone who at one time or another has destroyed nearly every part of his XJ.
No sense in wasting money unecessarily. IMHOGreg
After reading a few other threads I decided the clutch cable should be replaced as well. That showed up yesterday, so I changed that out this afternoon. Perfect! No more slip. The old one was pretty gummed up. I now see the importance of lubing it. I still plan to replace the springs when I get a chance. Thanks again for all your input.Ryan
1981 XS1100SH
K&N filter
Spade fuse block
Barnett SpringsComment
I just changed over my handle bar to a sportier one lots of excess cable length everywhere. I immediately noticed the slipped clutch sensation. Is this a classic symptom that appears when you relocate the clutch lever?Last edited by Nubian; 06-28-2011, 08:48 AM.BAMN!
'81 XS1100H "Brutus"Comment
If you have a lot of excess unsecured cable it can allow the cable to move instead of the cable moving the arm that actuates the clutch mechanism.Nathan
Theodore RooseveltComment
I went to put in the barnett springs today that I ordered off a link from one of these threads, and either I goofed, or they sent the wrong ones. Does any one have the part number for springs for an 81 special? I had ordered them from phat performance.Ryan
1981 XS1100SH
K&N filter
Spade fuse block
These are the ones I ordered... # 501-58-06045
http://www.phatperformanceparts.com/...14&Search.y=10Last edited by WMarshy; 07-07-2011, 06:27 PM.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
Those are the ones I got. They measure 2 1/4". Is that correct? Is that what makes them heavier duty? Or am I just going to break that plate tightening them? The manual specs the springs at just over 1.6". I've never worked on a clutch before, so please forgive my ignorance.Ryan
1981 XS1100SH
K&N filter
Spade fuse block
That doesn't seem right, mine were only 1-11/16" long. Take a look at this link...
'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
clutch slip or fuel....
not to hijack the thread....
but since a lot of you posted.....here is my issue...
Sunshine launches fine and pulls hard at almost every speed. im guessing i have a fuel problem, rather than a clutch issue.....
Cruising around at 55-65 mph, if i twist it hard, jets up to 75-80 with no problem, then gets this "hesitation" then pulls like a beast again until speedo is pegged....tach to about 7000. This hesitation comes around in 5th gear and approx 6000_6500 rpms....
Any thoughts???'81H (my first XS ) "Grey Ghost"
4:1 Jardine w/ headerwrap
Windjammer(wiring issues)
New paint/brakes to come!!
'80G FrankenBike (parts bike)
'80G to fix "BlackSunshine"
Stock Pilots/125 mains
Pod filters; 4:1 Kerker??
SS Brake lines w/ new M/C's
LED Brake Lite
Needs paint....
It is better to be thought a fool than to open ones mouth and remove all doubt....Comment
Next time you have the carbs out and apart take a close look at the diaphrams. You might have a pin hole, not allowing a slide or slides to lift in sync with the other cylinders. Unlikely but JAT... Otherwise, you might want to kill the engine at that RPM when it acts up and let it coast to a stop and read the mixture on your plugs. Have you checked the timing at all?not to hijack the thread....
Any thoughts???'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
Yeah, I checked again. The part number is the same as the one you listed. The springs are 2 1/4" inches long. And the bolts are longer than the ones I took out as well. I guess I'll have to make a call. Thanks.Ryan
1981 XS1100SH
K&N filter
Spade fuse block
I still have the Barnett box the new springs came in, I will check it when I get home. Probably wont be until 7...'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
