Clutch slip?
  • James England
    • 3039
    • North of England
    If you're in there, replace the friction plates anyway. Also replace the clutch release bearing. Well worth doing
      You could replace the friction plates but you might want to measure them first. Very rarely do I hear of them being below specs.
      The bearing might be a good idea, however, I have only heard of one of those ever going bad. It was destroyed by someone who at one time or another has destroyed nearly every part of his XJ.
      No sense in wasting money unecessarily. IMHO
      • Ebenezer
        • May 2011
        • 67
        • Hawley, MN
        After reading a few other threads I decided the clutch cable should be replaced as well. That showed up yesterday, so I changed that out this afternoon. Perfect! No more slip. The old one was pretty gummed up. I now see the importance of lubing it. I still plan to replace the springs when I get a chance. Thanks again for all your input.
        Ryan
        1981 XS1100SH
        K&N filter
        Spade fuse block
        Barnett Springs
        • Nubian
          • Apr 2011
          • 467
          • The Big East
          I just changed over my handle bar to a sportier one lots of excess cable length everywhere. I immediately noticed the slipped clutch sensation. Is this a classic symptom that appears when you relocate the clutch lever?
          BAMN!
          '81 XS1100H "Brutus"
            If you have a lot of excess unsecured cable it can allow the cable to move instead of the cable moving the arm that actuates the clutch mechanism.
            • Ebenezer
              • May 2011
              • 67
              • Hawley, MN
              I went to put in the barnett springs today that I ordered off a link from one of these threads, and either I goofed, or they sent the wrong ones. Does any one have the part number for springs for an 81 special? I had ordered them from phat performance.
              Ryan
              1981 XS1100SH
              K&N filter
              Spade fuse block
              Barnett Springs
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                These are the ones I ordered... # 501-58-06045
                http://www.phatperformanceparts.com/...14&Search.y=10
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                '84 Chevy K-10 "Big Blue"
                • Ebenezer
                  • May 2011
                  • 67
                  • Hawley, MN
                  Those are the ones I got. They measure 2 1/4". Is that correct? Is that what makes them heavier duty? Or am I just going to break that plate tightening them? The manual specs the springs at just over 1.6". I've never worked on a clutch before, so please forgive my ignorance.
                  Ryan
                  1981 XS1100SH
                  K&N filter
                  Spade fuse block
                  Barnett Springs
                  • WMarshy
                    • Apr 2009
                    • 2402
                    • Mexico NY
                    That doesn't seem right, mine were only 1-11/16" long. Take a look at this link...
                    '79 XS11 F
                    Stock except K&N
                    '79 XS11 SF
                    Stock, no title.
                    • TomRodgers
                      • Jun 2008
                      • 492
                      • La Porte Indiana
                      clutch slip or fuel....
                      not to hijack the thread....
                      but since a lot of you posted.....here is my issue...
                      Sunshine launches fine and pulls hard at almost every speed. im guessing i have a fuel problem, rather than a clutch issue.....
                      Cruising around at 55-65 mph, if i twist it hard, jets up to 75-80 with no problem, then gets this "hesitation" then pulls like a beast again until speedo is pegged....tach to about 7000. This hesitation comes around in 5th gear and approx 6000_6500 rpms....
                      Any thoughts???
                      '81H (my first XS ) "Grey Ghost"
                      4:1 Jardine w/ headerwrap
                      Windjammer(wiring issues)
                      New paint/brakes to come!!
                      '80G FrankenBike (parts bike)
                      '80G to fix "BlackSunshine"
                      Stock Pilots/125 mains
                      Pod filters; 4:1 Kerker??
                      SS Brake lines w/ new M/C's
                      LED Brake Lite
                      Needs paint....
                      • WMarshy
                        • Apr 2009
                        • 2402
                        • Mexico NY
                        Any thoughts???
                        Next time you have the carbs out and apart take a close look at the diaphrams. You might have a pin hole, not allowing a slide or slides to lift in sync with the other cylinders. Unlikely but JAT... Otherwise, you might want to kill the engine at that RPM when it acts up and let it coast to a stop and read the mixture on your plugs. Have you checked the timing at all?
                        '79 XS11 F
                        Stock except K&N
                        '79 XS11 SF
                        Stock, no title.
                        • Ebenezer
                          • May 2011
                          • 67
                          • Hawley, MN
                          Yeah, I checked again. The part number is the same as the one you listed. The springs are 2 1/4" inches long. And the bolts are longer than the ones I took out as well. I guess I'll have to make a call. Thanks.
                          Ryan
                          1981 XS1100SH
                          K&N filter
                          Spade fuse block
                          Barnett Springs
                          • WMarshy
                            • Apr 2009
                            • 2402
                            • Mexico NY
                            I still have the Barnett box the new springs came in, I will check it when I get home. Probably wont be until 7...
                            '79 XS11 F
                            Stock except K&N
                            '79 XS11 SF
                            Stock, no title.
                            • Ebenezer
                              • May 2011
                              • 67
                              • Hawley, MN
                              The sticker/part number on the outside of the package is right, but the sticker/part number on the inside insert is wrong. Their screw up, not mine.
                              Ryan
                              1981 XS1100SH
                              K&N filter
                              Spade fuse block
                              Barnett Springs
                                That's the # listed for 78-81 XS1100.....
                                Yours came with bolts? All I got was springs.
