Plug wire question
  • XSive Okie
    • Jun 2010
    • 281
    • Enid, OK
    Plug wire question
    Are the OE plug wires from stock coils a thick copper wire or a very thin silver wire. Still having trouble with 1 and 4 running rich, and was checking to see that corrosion wasn't the issue. Unscrewed the #4 boot and all I found was a thin little silver wire, about the diameter of speaker wire. In my head I'm comparing to what guage automotive systems use, and wondering if I need to cut the jacket back and find a bigger lead?
    Richard
    '79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
    '02 Honda VTX1800C
    • 5069
    There should be several wires in the stock high volt plug cables. If you have enough cable left, cut about a half inch off. I like to trim the insulation a just a little bit back so that I can locate the center of the standed wires and screw the plug connector into that. The connectors can go bad as well.
    • XSive Okie
      • Jun 2010
      • 281
      • Enid, OK
      Thanks, Skids. I do have enough left, so after work I will probably trim them back, and take the boots apart as well!
      Richard
      '02 Honda VTX1800C
