My XS400 has the same carbs, and with the o-rings almost gone, it could NOT be tuned to idle properly no matter what I did. I replaced the o-rings (you can get them and the washer and spring from MikesXS as a kit, it in part I believe to keep water and stuff out as well since that's down in that well that stuff can get down into, but it WILL suck air, and not sucking ATF doesn't tell you anything about sucking air, as air will go through where ATF will not, being that ATF is far far far thicker than air. But I speak from experience when I say that those being bad does affect the tuning ability of the late model carbs. It's well known in the 650 and 400 circles, as it's one of the common causes of an inability to get a solid idle on those models with the late model Mikuni carbs.
Quick carb question and notes...
I was always taught to respect my elders, but it keeps getting harder to find one. -
o-rings almost gone, it could NOT be tuned to idle properly79SF
XJ11
78EComment
How about another crazy notion I have that will stir the pot.Side bleed holes in the pilot jets. My puzzler started here when I cleaned the XJ carbs and found no holes. Suspecting wrong jets POed started checking and found most likely original. Been a lot said about those holes or lack of being an issue.Studied a 79 body on my desk and remembered the caveat under the jet chart at MikesXSNote: BS 30/96 type Pilot Jets WITH Side bleed holes
holes and those without side bleed holes are
completely interchangeable.
I do agree as with those tiny O-rings that without a conclusive test all things should be replaced as originally installed.79SF
XJ11
78EComment
I think the 'potential vacuum leak' scenario is overplayed too. However, I do think the slight squashing of the o-ring around the screw gives a bit of friction to keep the screw where you set it. With heat and cool cycles and vibration, it seems to me the screw might tend to wind itself in or out a bit.Ken TalbotComment
I think the 'potential vacuum leak' scenario is overplayed too. However, I do think the slight squashing of the o-ring around the screw gives a bit of friction to keep the screw where you set it. With heat and cool cycles and vibration, it seems to me the screw might tend to wind itself in or out a bit.79SF
XJ11
78EComment
I think the 'potential vacuum leak' scenario is overplayed too. However, I do think the slight squashing of the o-ring around the screw gives a bit of friction to keep the screw where you set it. With heat and cool cycles and vibration, it seems to me the screw might tend to wind itself in or out a bit.Cy
How about another crazy notion I have that will stir the pot.Side bleed holes in the pilot jets. My puzzler started here when I cleaned the XJ carbs and found no holes. Suspecting wrong jets POed started checking and found most likely original. Been a lot said about those holes or lack of being an issue.Studied a 79 body on my desk and remembered the caveat under the jet chart at MikesXS and having sprayed, and cleaned the 79"s so many times with no evidence of any passage (nor obviously visible on the body)(nor any flow chart i've seen) to any area those holes could go to. I think they are there because these jets were used in some earlier design and have no function in fact in these carbs.
the stock pilot jets for the aussie 81rh are 40 with no bleeder holes,
ive bought the aftermarket jets that have been discussed not only do they
have 8 bleed holes but i measured the centre hole and it was closer to a size 50 than the stated 42.5 thats stamped on them which causes them to run rich.
i tried searching to see what the actual differences are between the pilot jets that have bleed holes compared to the jets that dont, it was a late nite and i didnt save the page and my memorys starting to fade but it had something to do with the holed jets running leaner through out the later stage of the idle circuit, the rh is also fitted with adjustable needles and the emulsion tube is also different to the corresponding 81 us model, if that has anything to do with it, i dont know.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
