carb parts sources
  • graybird78
    • Apr 2003
    • 360
    • council bluffs iowa
    carb parts sources
    need new float needles and seats. bike is 80sg. who is good source for these parts.2 of the seats are sticking.tried 2 clean no avail.thnx.:
    when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
    graybird78
    80 sg (old faithfull)
    • 8930
    Part # 48-1445, fits 1100, scroll down...
    http://www.mikesxs.net/products-35.html#products
    Part # 48-1408, scroll down...
    http://www.partsnmore.com/parts/yamaha/xs1100/?filters[fitting]=custom
      • 9981
      Check these 2 .....
      http://www.mikesxs.net/ This is a XS650 parts dealer but the have the same carbs as our 11s.
      http://www.carbkitscapital.com/
        • 8077
        Some more:
        http://store03.prostores.com/servlet...AHA/Categories
          • 8077
          Still more:
          http://www.650central.com/ has genuine Mikuni. Just match the same year XS650 to XS1100. Be advised, carb bodies are NOT the same, but most parts are.
          http://www.motorcyclecarbs.com/FLOAT...P15493C839.cfm
          • graybird78
            • Apr 2003
            • 360
            thnx 4 replys. 650 carb parts same as our bikes! any one use any of these parts from these suppliers. any pros or cons.
            graybird78
              • 8077
              When you buy parts from a XS650 supplier, make sure it is for the same year bike. XS650's used some different carburetors over the years.
              Any of the suppliers listed should be fine.
                80 to 84 650's use the same carbs as the 80-81 XS1100's do.
                  • 8077
                  ALMOST. Don't try to swap in a XS650 carburetor or carb body. They look the same, but they aren't. Yes, you can use XS650 carburetor parts.
                    Well, I think you COULD if you replaced ALL the jets, but since some of the air jets are perm pressed in that could be tough and yes, those are different. Also the metering passages and spring rates on things like the vacuum slides are different which is an issue, as well as the external passages are handled differently so it would be a daunting task, which while it may be possible if the right carb body cannot be found, I don't think would be worth the worked required. There has indeed been a lot of talk about this issue on XS400 and 650 boards and the same thing has been determined, it might be possible to repurpose, but it's not worth the work. You would however probably swap ALL the bodies from another set, since they would at least all be matched and then it would just be getting them tuned rather than trying to tune a mismatched carb which I agree might be close to impossible (it you HAD to do it, replacing the whole bank with 650 or 400 carbs would be the way to go IMHO).
                    • graybird78
                      • Apr 2003
                      • 360
                      not wanting to use 650 carbs.I need to replace the float needles and seats. riding home from work the other night.lost 2 cylinders. cause was #1-4 carbs flooding bad. took carbs off cleaned and blew carbs out. #4 now ok, but #1 still flooding. took off again, float needle is sticking.yammy dealer no got parts. hoping he will have for 650.
                      graybird78
                        • 8077
                        I tried the 650 carb body swap. A lot of work as Cy pointed out. It didn't work. I think all the 650 carb parts swap over except the bodys.
