So I have been reading and reading and reading even more. I am going to list what I have done and would like suggestions of anything else you guys think I should do to feel entirely satisfied with my bike.
Done:
New Dunlop D404 Tires
Rear Wheel Bearings
Greased the Shaft Drive Gears the right way, ie: on the splines themselves
Carb clean and replacement of nec. parts (set float height to 23mm) No leaks
New handle grips to reduce Vibrations
Complete brake overhaul (will decide on SS lines after riding)
Clutch adjustment (still need to determine if I did it right )
Thorough Cleaning
New Spark plugs
Battery Charge (With Battery Tendor)
Will be doing:
CCT adjustment
Seat Repair
Tank Cleaning
Compression Check
Changing oil again
Changing gear oil and replacing FD filler plug that I stripped trying to get out
Replacing Oil Filter bolt that I did the same thing on
Is there anything major that I am leaving out that I should be doing before really riding this thing. After 2 1/2 weeks of being down I wanna make sure everything is golden before I consider myself done I know there will be more things to do later and things I plan on doing over storage season, but will the things I did get me there, and get me there safely, of course after riding cautiously and making sure I did everything right.
If I am good,(I'll let you guys decide ) I will take it for a test ride after I break in the new tires and brakes and repost how it is riding after the upgrades and repairs.
Look forward to hearing what I shorely missed.
Done:
Rear Wheel Bearings
Thorough Cleaning
New Spark plugs
Will be doing:
CCT adjustment
Seat Repair
Tank Cleaning
Compression Check
Changing oil again
