I need new "O" rings for the carb float needles in the newer carbs and can't seem to find them locally. Does anyone know where I can get them?
Source of
Source of
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesTags: None -
They are from Rocket Seals in Denver. They are about five blocks from me, so it is no big thing to run up there. I'll have to take a carb apart to get the size, unless you have a set of metric calipers to measure yours with.
Let me know. CZ -
Go to Harbor freight and buy an o-ring set. They have Nitrile or Viton. The Viton is spendier but will last longer.'81 XS1100 SH
Sep. 12th 2015
RIPComment
Size
Captain, I'll measure the ones I got for you, and I am going to the rally in Durango... I've been to many places here, but they are metric and they are not included in any sets, especially from Harbor Fright. I could go to my local Bearings and Drives, but they have to order and then there is a minimum.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Stainless braid brake linesComment
Captain, I'll measure the ones I got for you, and I am going to the rally in Durango... I've been to many places here, but they are metric and they are not included in any sets, especially from Harbor Fright. I could go to my local Bearings and Drives, but they have to order and then there is a minimum.Nathan
Theodore RooseveltComment
"O" ring size
CaptainZap, the "O" rings need to be 2 mm thick with an inside diameter of 7 mm and I certainly do appreciate the help. I have a large selection of "O" rings since I do industrial repairs, but even the metric ones are not thin enough though there are the right ID ones in the kit. I really don't want to buy another whole kit even if there are the ones I need in it.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
I am working tonight but I bought a bunch from someplace online. Can't remember where exactly right now and I haven't put them in yet. I will measure them when I get home and if they will work I can get you 4 or 8 if you want future replacements. Prolly have like 20 of them. I can repost tonight for you so you know for sure.1980 XS1100SG "Black Mamba" 28K
1979 XS1100F 33k (Current Project)
1981 XS1100H "Blue Balls" (Crashed and under repair)
1978 XS1100E "Partsy"
Work Hard, Play Harder!Comment
Hey Dick,
For what it's worth, I dug around in my can-o-parts and found the wrapper that the o-rings came in, and it said that the size is 1.5 X 7.
As I remember, when I bought them, we tried 2 X 7, and they would not smoosh down enough to go in the hole.
Did you find some yet? CZComment
Other problems
No I haven't found anything yet and I did put the old ones back in after cleaning and using soap to make them slippery so as not to break them. The carbs are the least of the worries now. Compression test shows 150-140-140-0. Compressed air in spark plug hole comes out intake, rotated crank 360 just to make sure it wasn't supposed to be open and still open. I checked piston by putting compressed air in the crankcase vent and nothing came out plug hole, so I'm assuming bent valve since I found the CCT mounted upside down which tells me the PO did some tinkering and didn't know what he was doing. I'm expecting to find a timing problem also.You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
