Carb ID
  • old_chopper
    • Sep 2010
    • 120
    • Oklahoma
    Carb ID
    I posted about stumble I was having just off idle to about 3K rpm and the broken #3 carb body. I found a rack of carbs that were labled "1979 XJ1100", pretty sure that's not happening. Anyway they looked very good, mixture jets still capped, so I bought them. I was amazed when I opened them up, super clean inside. The pilot jets only have the center hole, not the 6 cross holes. They have the vents built into the mouth, no tubes. They have a cable operated enrichener (choke). No rubber plugs covering the pilot jets. I'm guessing '80 or newer, do you think they are XS or not?
    I still have the slight stumble but it's much better. I think it's a touch lean until the needle comes on so I'm going to back the mixture jets out 1/2 turn more and try it.
    US Army 1986-1991
    1979 1100 Special (on the road after 16 years!)
    1983 GS300L (wifes ride)
    1985 Super Glide
    2012 Super Glide
    The cable operated choke identifies those as XJ carbs, as they were the only model with that feature. So they're the late style carbs, and should be jetted to the year of them...
    • old_chopper
      • Sep 2010
      • 120
      • Oklahoma
      Cool. I "THINK" the mains were 117.5 but I didn't have my binoculars on. It was nice to find a set that hadn't been tampered with. I also found several sets of GS carbs that were the same size, something to consider for future needs.
      US Army 1986-1991
      1985 Super Glide
      2012 Super Glide
        Sunding like XJ carbs and mains were 112.5's all across. Having the bowls off them, spray some carb cleaner through all orfices , leaving jets, etc. in tact(if there 112.5's)......plug and play them........likely put a smile on........
