The idea behind using the RTV is that you don't use so much that is squeezes out past the mating surfaces. It doesn't take a rocket scientist or a master artisan to apply a 1/16" bead of the stuff along the mating surfaces in such a way that you only get a slight squeeze-out on each side. Yes, I agree that there are those "PO's" that insist on using their finger to spackle the stuff on there, leaving a drooling mess, but you can't blame the product for that... If the mating surfaces are so poorly constructed that there is a 1/16" gap for the stuff to fill in, there is something else wrong, and that needs to be fixed first.
The normal application method requires that you completely clean all oil residue from both mating surfaces. Then, apply a THIN bead to one of the surfaces. Then, mate the surfaces, only fastening the bolts FINGER TIGHT! Wait an HOUR for the stuff to cure a bit, creating the gasket, then, torque the bolts down. The stuff I use, "The Right Stuff", in a can, does not require completely clean surfaces or the hour of waiting before tightening the bolts. Plus, the applicator tip makes it a MUCH easier job to apply a clean bead.
Cleanup is much easier the next time you need to get in there if you use RTV as well, since the stuff comes right off with a wire toothbrush. No need for the jack-hammer or needle scaler required to get a crusty paper gasket off.
