Carb Vent
  • gaillarry
    • 32
    • Ontario Canada
    Carb Vent
    XJ 1100 Maxim. Removed the octy mess of hoses from the carb rack. Now the carbs are overflowing into the air box. Looking at the carbs I note there is no vent line, just two fuel lines. Shouldn't there be one??
    1980G Tourer
  • petejw
    • 2269
    • sydney australia
    hi gaillarry,
    the later model carbs dont have the vent tubes
    like the early model carbs do,
    they vent out the back of the carb bell,
    if ur leaking fuel out into the air box, either the
    needle and seat isnt sealing or the 'o' ring around the
    seat is leaking. youll have to remove the carbs and suss it out.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • gaillarry
      • 32
      • Ontario Canada
      Thanks, luckily I ordered 4 new seats/valves, should be here today.
      1980G Tourer
      • Yahman
        • Mar 2008
        • 779
        • Salem, OR
        You might want to change your oil too. If there's fuel flowing into the air box, it's probably in your oil also. Not worth the chance of destroying your engine.
        Larry
        82 XJ1100
        80 XS1100G (Project bike)
        64 Yamaha YA-6
        77 Suzuki TS-185
