Need quick anwser
  • lancelot455
    • Sep 2010
    • 174
    • Regina,Saskatchewan,Canada
    Need quick anwser
    About to do the cct upgrade just need to know if this is the proper position to remove the cct.
    82 XJ1100
    Canada
    2006 V-Star 1100 custom
    Assuming that picture is not in normal orientation, yes. You want the timing pointer to ne aligned wiht the C Mark. Also, have the bike on the centerstand, NOT the side stand.
    • lancelot455
      • Sep 2010
      • 174
      that picture is in the orientation as it sits on the bike. the bike is on a jack. I just took the picture....The bike is an XJ
      82 XJ1100
      Canada
        ok, never sen an XJ, but yes, you want the C lined up with that pointer. As long as the bike / Engine is level and not leaning to one side or another.
        • lancelot455
          • Sep 2010
          • 174
          thanks so much..Going to the back to pull it now
          82 XJ1100
          Canada
          • James England
            • 3039
            • North of England
            What pointer? I don't see one. It looks like a cable clamp to me......
              Since the XJ has neither mechanical or vacuum advance I suppose that is why it is set up in a different spot.
                Hey James,
                According to the XJ service manual, that tab at 12 o'clock IS the timing pointer, it's supposed to have a line in the middle of it, but it's hard to see in that picture.
                TC
                • lancelot455
                  • Sep 2010
                  • 174
                  Got the tensioner changed. What a pita that was. had to file out some of the bottom right side hole to get the bolt in. Turns out that the po stripped the bottom bolt out. I was able to get a longer bolt in there. The old tensioner lock bolt was not engaged.When i removed the tensioner it literally popped out. Now the bike pops at low rpm's when i let off the throttle, On a good note the oil leak is fixed and it was 23c here today.
                  82 XJ1100
                  Canada
                    Glad you gotter' dun!........now go and re-sync those carbs again now that it is running with correct valve timing.
                    • James England
                      • 3039
                      • North of England
                      Hey James,
                      TC
                      Hi TC. Aha! I dimmed my screen a bit after reading your post and saw a shadow of a line there. I see the pointer can be altered if the screw holding it (with the yellow on it) is loosened. Not so with he XS11 pointer (is it?).
                      • CatatonicBug
                        • 6117
                        • Clinton, UT
                        It's very much adjustable on mine. Just a big arm attached with 2 bolts. Can be either bent or adjusted by loosening the bolts.
                        • SFerinTEXAS
                          • Jun 2006
                          • 877
                          Just thinking........... The adjustability of that pointer was for the factory to set TDC. If it (pointer) is never disturbed there is no reason to move it. TDC, timing plate and crank position are non variable. They never change with wear.
                          79SF
                          XJ11
                          78E
                          • James England
                            • 3039
                            • North of England
                            I'm wondering then.... if a PO has moved the pointer on the bolts (which would not be noticeable like the pointer being bent) then adjustment of the camchain, and ignition timing using a strobe, would be inaccurate. These adjustments all refer to the pointer as if it's a fixed, immobile reference point, don't they? Just a thought. I just adjusted my cam chain and strobed the timing, using the pointer, without actually questioning whether the pointer was in the right position.
                              • 8930
                              James, if you're not sure you're timing pointer is in the correct position, a dial indicator may be used thru the #1 spark plug hole to find true TDC. Or... you can do it by eye using a soda straw.
