Oil drain plug
  • ManagerMike
    • Mar 2010
    • 445
    • S.E. Michigan
    Oil drain plug
    FYI crew, perfect oil drain plug replacement. NAPA once again, pn: bk 704-1902 and has a captured 'o'-ring gasket!
    '78 E "Stormbringer"
    Doesn it fit well as a replacement for the middle and final drive fill holes?
      No magnet? Then it's not perfect.... But still good to know.
      If I might be so bold, may I suggest to the Mods that a 'parts interchange' forum be added to the 'repairs' or 'mods' forums? Then info like this could be posted there for ease of finding. The Jaguar site I go to has this, and it's an invaluable resource. For that matter, could some newer, updated info be posted to these forums? They're both 'locked', and neither has had any updates for several years...
      • ManagerMike
        • Mar 2010
        • 445
        • S.E. Michigan
        OK, maybe not "perfect", but the OE plug isn't magnetic either.
        It will work for the md, but not the fd.
          It will work for the md, but not the fd/............very true, the smaller ID recess won't allow the large OD of the plug to work. BTW, That is the same plug used on the Ford Escape 3.0V6....and yes, that is also a Yammy motor!
          • Nubian
            • Apr 2011
            • 467
            • The Big East
            [QUOTE=crazy steve;327664]No magnet? Then it's not perfect.... But still good to know.
            Can the magnetic drain plugs from the middle/final drives be used as the engine drain plug?
            BAMN!
            '81 XS1100H "Brutus"
            • planedick
              • Mar 2005
              • 2068
              • Yorba Linda, California
              Magnetic
              I had one of those magnetic plugs and found that the thread was not quite to specification. Probably made in China as it was loose and eventually destroyed the threads in the pan because tightening it enough to make it seal would strip the threads...
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
                Threads on all the drain plugs and then the middle and final drive fill plugs are all the same aren't they?
                • James England
                  • 3039
                  • North of England
                  Re the non-magnetic quality of this drain plug..... here's a little idea that I've used a lot. If you have an old computer hard-drive, eg when upgrading PC or whatever, take it to pieces. Inside them are the most powerful small magnets! Get into the hard drive and destroy it, prising out the small silver magnet which usually has a little lug on one side of it. They really are super-thin and flat and very powerful indeed; it's difficult to separate two of them joined together.
                  What I've done in the past (before using a spare FD plug in the oil pan) is to put one of these little magnets onto the drain plug. They end up magnetising the whole plug eventually. Incidentally, they are great for just sticking on the ferrous sump on cars. I have half a dozen on mine and I doubt any ferrous particle gets past them.
                  Of course, these little magnets are also great for messing about with but....watch your fingers!
                  • Nubian
                    • Apr 2011
                    • 467
                    • The Big East
                    Found one that's magnetized product # 65216 made by OIL-TITE! M14-1,50
                    2nd image shows comparison between original engine drain plug and new magnetized product
                    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                    about 3/8th of a difference in length. is this ok?
                    3rd image shows middle gear plug comparison http://s1087.photobucket.com/albums/...3DIMG_3581.jpg
                    also about 3/8th difference in length.
                    Again will these increased lengths interfere with the internals?
                    item photo
                    BAMN!
                    • Nubian
                      • Apr 2011
                      • 467
                      • The Big East
                      Sorry, next time will post photo's not links. Still learning this system
                      BAMN!
                      • WMarshy
                        • Apr 2009
                        • 2402
                        • Mexico NY
                        I just picked up a pack of aluminum crush washers for my middle drive made by the same company. If you replace them every once in a while you don't need to torque the hell out of the drain plugs to get them to seal up. The one I removed from my middle drive grudge crushed I thought it was part of the bolt!
                        I agree though, the magnet is necessary especially for the middle drive...
                        '79 XS11 F
                        Stock except K&N
                        '79 XS11 SF
                        Stock, no title.
                        '84 Chevy K-10 "Big Blue"
                        • Nubian
                          • Apr 2011
                          • 467
                          • The Big East
                          Can you provide a product #/id and where they can be obtained?
                          BAMN!
                          • WMarshy
                            • Apr 2009
                            • 2402
                            • Mexico NY
                            Im using them on the middle drive drain and fill plugs and the engine oil drain...
                            I've used the engine drain washer about 4-5 times and its ready to be replaced next time. I got them at Advanced Auto, 4 in a pack.
                            '79 XS11 F
                            Stock except K&N
                            '79 XS11 SF
                            Stock, no title.
                            • Nubian
                              • Apr 2011
                              • 467
                              • The Big East
                              item photo
                              I am impatiently waiting to crank my newly named "Brutus" as soon as someone replies to this post.
                              BAMN!
