engine paint
  • chpzenker
    • Nov 2010
    • 18
    • South East Texas
    engine paint
    What type/brand of paint would ya'll recomend for painting the engine.
  • jwhughes3
    • 2798
    • Home of the Alamo
    oil based enamel
    I've heard a good case for good old brush on oil based enamel. I've seen the pics and they look good and its durable. Sounds easy too.
    John
    '81 XS1100H - "Enterprise"
      Not sure where the thread is, but is very recent. Check out CrazySteve's simple curing process using the motor for gradual curing..........
        I can't even find the post....
        Anyway, use a quality oil base enamel and brush it on. Note that this is for the barrels/head, although you could do the rest of the motor if you wanted. Works well on the rough-cast of the top end. Cure by starting the bike and warming it until you just start to smell paint, then shut it off. Let it cool, then repeat. Do this until the paint smell starts to fade (6-8 times). Then start over, but now let the bike come up to full temp before shutting it off. About another 4-6 times, the paint smell should have pretty much faded by now, and you're good to go.
        For the lower cases, a good quality rattlecan will work; I used Eastwood wheel paint as the color's pretty close and it has the right semi-gloss sheen.
        • chpzenker
          • Nov 2010
          • 18
          • South East Texas
          Not going to be able to do the start stop on the enamal paint. Engine is out of the frame. I've seen on anouther post were they sandblasted the engine and then painted it. I think with rattle cans.
            Originally posted by chpzenker
            Not going to be able to do the start stop on the enamal paint. Engine is out of the frame...
            Best time to do it; that's when I painted mine. The paint will dry, just to prevent burning it after it's in the frame and you can run it, that's when you cure the paint...
            • James England
              • 3039
              • North of England
              PJ1 satin black case paint or gloss black case paint is superb stuff. Full of harful chemicals and so on, so it must be good. I've used it for 25 years and it's still as good as it ever was. These pix are the satin black, which is virtually indistinguishable from the factory finish.
              • Shacknasty
                • Feb 2011
                • 379
                • SFV-SoCal
                This was painted with Rustoleum Engine enamel aluminum. It was black peeling paint and loads of rusty fins. Looks pretty good. I've used it in the past and had good results with durability. Prep is the key to a long-lasting paint job.
                • chpzenker
                  • Nov 2010
                  • 18
                  • South East Texas
                  What type of prep work is involved. I would like to only have to do this once.
