Rear LH wheel bearings
  • James England
    • 3039
    • North of England
    Hi Folks. I just found some Yamaha OEM left side rear wheel bearings on eBay...
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...EOIBSA:GB:1123
    I bought one. There's four left at present. New old stock.......
    thats not a bad price!
    • planedick
      • Mar 2005
      • 2068
      • Yorba Linda, California
      Bad deal
      That's not the one that's hard to get. That's the right side bearing which is available everywhere for cheap.
      Drilled airbox
      Tkat fork brace
      Hardly mufflers
      late model carbs
      Newer style fuses
      Oil pressure guage
      Custom security system
      Stainless braid brake lines
      • jwhughes3
        • 2798
        • Home of the Alamo
        I think its right by PN
        The fiche shows:
        Left Rear (Not Available) 9331362010
        BRG.CYL-CAL ROLLER 11
        € 62.00
        Right Rear 9330630417 (93306-30437) BEARING(3BC)
        Note: this part is superseded by 9330630437. € 23.00
        Maybe I am looking wrong.
        http://www.cmsnl.com/yamaha-xs1100g-...list/F-12.html
        John
        '81 XS1100H - "Enterprise"
          looks like the right part number to me too.
          • James England
            • 3039
            • North of England
            It's the correct part number and described as "rear left". The photo is taken from the side, so it looks like the wrong bearing. I hope. I ordered one and it's been despatched, so I'll be able to report back soon
            • cywelchjr
              XS-XJ Super Guru(Deceased)
              • 4450
              • Sacramento, CA
              Looks right to me. The right side bearing looks a good bit different that that, and is taller, with a higher profile to the bearing section where the balls are, that one is clearly not a ball type bearing, there is not room for balls between the inner and outer races.
              • planedick
                • Mar 2005
                • 2068
                Looks like
                Although not for the xs11's, this is what the left hand bearing looks like...
                Drilled airbox
                Tkat fork brace
                Hardly mufflers
                late model carbs
                Newer style fuses
                Oil pressure guage
                • James England
                  • 3039
                  • North of England
                  I received the bearing today. It's the correct part, OEM Yamaha, also etched on the outer race with the part number and bearing number. Def. the real McCoy
                  https://
                    And now they are sold out.
                    • James England
                      • 3039
                      • North of England
                      I just saw that the remaining 4 were bought by the same person....... greedy, or just good business? Or planning on doing two million miles?
                      • planedick
                        • Mar 2005
                        • 2068
                        Would like
                        I should get precision measurements of the inner race. I have the facilities to at least manufacture the inner race as that is usually the part people need as it sometimes falls out while mounting tires. Happened to me once, got the tire home and was putting it in the bike when I noticed it was gone. Went back where the store was mountd and they had no knowledge of it or where it was. I got lucky and found it on the floor. If I could just remember to measure it next tire change...........
                        Drilled airbox
                        Tkat fork brace
                        Hardly mufflers
                        late model carbs
                        Newer style fuses
                        Oil pressure guage
