Front Caliper?
  • DCII
    • Jul 2010
    • 792
    • Centerville, Ohio
    Front Caliper?
    I am in the process of redoing the front brakes on my SG and noticed that when I pulled the calipers off I only had a retainer clip on one fork. Does anyone know if you can still get these at the dealer? If not I could use some suggestions on where to get them.
    Thanks
    DCII
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    Do ya mean these...??
    If you do then Fleabay or Andreas would be your best bet, although a member here may have some lying around... or you can build your own...
    • DCII
      • Jul 2010
      • 792
      • Centerville, Ohio
      That's the part I was referring to, after noticing it was missing from the SG I am working on I decided to look at my other one and there were none on it either. Maybe this is why every dog in the neighborhood starts howling when I use my brakes. Now to see if I can find some.
        How about make some?
          Those are fairly important 'cause if they're missing, it allows the brake pads to wear the contact point of the forks. Get a worn spot in the aluminum, this can restrict the pad movement and cause uneven wear and/or dragging brakes.
          • b.walker5
            • Feb 2009
            • 1745
            .... and cause the pads to click as they flip forward and fall backward in the slot at low speed. Drove me nuts for years until I got new clips sent out from someone here. Sorry, can't remember exactly who at this point, but I think Ray and Don had something to do with it.
            I used one of them to measure and produce the drawing, and have made one, which works perfectly. Took about an hour with some 20g sheet, sharp tinsnips, vice, pliers and a hammer.
            • BigRed
              • Mar 2010
              • 265
              • Ottawa, Ontario, Canada
              Thanks for the drawing! I've got the same clicking at low speed problem that you were having, and it is a little maddening.
              • DCII
                • Jul 2010
                • 792
                • Centerville, Ohio
                Thanks for your feedback on the retainer clip, the drawing will be big help in trying to make some.
                  • 8891
                  Here you go, buy them from NW Vintage....
                  http://www.nwvintagecycleparts.com/s...01-00&st=spart
                  Part # finder....
