Caliper shim missing - XJ11 L front - UhOh?
  • Filter
  • Caliper shim missing - XJ11 L front - UhOh?
    Starting to remove the piston from the stuck caliper and it looks pretty rusty inside. To make it more interesting there's no diagonal shim on the back of the brake pad.
    I might have to get a new piston & rebuild, won't know till I get it out & polish the piston & look for pitting.
    What's the shim for, there is none with the EBC brake pads I bought so I don't have one to replace that with. Is it essential?
    Love, just love the PO on this bike...
  • #2
    Not essential. Lots are missing.
    • #3
      Thanks for the reply. I was surprised there wasn't one that came with the new brakes but nope, not present. I wonder what its purpose is if it's not always being used.
      Funny how the other caliper looked almost new mechanics-wise & this one looks nasty with rust. I'll have it out tonight & will see what's the damage.
      • #4
        as nate said, there not essential,
        they're basically there to help prevent
        the brakes from squealing,
        if u want, u can make 1 up using an old
        soft drink can, cut and bent to size.
        these sintered pads come with the shims.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • #5
          Thanks for the replies.
          As Pete suggested I think I'll make one. I need to check on my XJ650 Maxim too, to see if there's one missing. when I stop, that bike squeals like a 5 year old with their hand caught in the cookie jar.
