Uh oh...??
  • g15usmc
    • Nov 2010
    • 365
    • 29 Palms CA
    Uh oh...??
    So I modified my 20 bar ends do they would fit my bars...I had to cut about a half inch off them because they had a solid piece that is supposed to slip inside the handlebar along with the piece of rubber that you tighten down and holds the bar end in place...so the rubber and this extension of the bar end were too big...after cutting the extra piece of bar end off I decided to use a piece of 3/8 fuel line in place of the rubber...it worked magnificently...so after this i started looking at the bike to find a place to relocate the footpegs...i want to move them back about 3 inches or so...so there i was looking and i decided to play with the shift lever a bit to see what i could do to keep from having to get some kind of kit for it...i decided that i could flip the bar and just click down to shift up...i think it will work great...now the bad news comes in...I removed the lever but as i was doing so i noticed that I have OIL on the shaft that sticks out in order to shift...I think this is an Uh oh...and I'm wondering what i'm going to need to do to fix this...
    All help appreciated!
    Daily Driver - '04 Suzuki Marauder 1600
    Project Bike - '79 XS1100 Special
    Hi my name is Nate and I'm am Addict...I quit riding every night before bed and can't help but start riding again the next morning...
    Ride Till You Die!
    "MESS WITH THE BEST DIE LIKE THE REST" -Semper Fidelis!
    “Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.”
    "When in doubt, Gas it!. If it doesnt fix the problem, at least it will end the suspense!"
  • Eveready1100
    • 539
    Tis ok mate, firstly how much oil?
    If it's only a thin film, don't worry about it and carry on with your plan.
    If it's a fair amount, just grab a new seal, pull the cover behind the shaft, swap it over, refit and carry on with your plan.
      If. The seal needs to be replaced, remove the cover and take the seal to a bearing supply place and they can get you a new seal. I got one for 3 bucks.
        You can still get that seal from Yamaha; it's still an active part number, as it's used on current bikes...
