XJ11 Engine paint & other paint
  • KA1J
    • 664
    • Groton, CT
    I'm at the point in this rehab I need to decide on which paint to use. There's some rust spots on the frame I need to touch up, I've got the calipers that need repainted and then there's the cooling fins & Valve cover.
    None of those are going to need the 2,000F paint & probably 500F paint will be fine for all. Do I use gloss or flat black?
    Any brand of spray can that seems to work best?
    Thanks
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    I have used Duplicolor Engine Enamel a few times with great results, as long as your part does not get over 500 degrees. It breathes well and is durable and they also have a clear over coat that can be used to keep your finish nicer longer.
    Mike Giroir
    79 XS-1100 Special
    • Bulldog9
      • 31
      • Alexandria, VA
      PJ-1 is the only paint I have seen that is almost and exact OEM finish and durability.
      2005 FJR 1300 "Mission" (NON ABS)
      1979 XS 1100 SF "Visitation" Owned since 1984 - SS Brake Lines, TKAT fork brace, Progressive Fork Springs.
      1978 XS 750 D "Motivation" - 9" rear custom shocks, dropped front end, shaved seat
      When Caged:2006 Jeep Commander, 1986 Cutlass 442, 1976 Porsche 912E (latest project)
      • KA1J
        • 664
        • Groton, CT
        Duplicolor I've heard of and it's at AutoZone.
        PJ-1 I haven't heard of. Where is it usually found & which color do I look for? Gloss black or flat black?
        Thanks
        • Yahman
          • Mar 2008
          • 779
          • Salem, OR
          You can get PJ-1 at http://www.z1enterprises.com/detail.aspx?ID=1752. It's excellent paint. You might find it at your local cycle shop.
          Larry
          82 XJ1100
          80 XS1100G (Project bike)
          64 Yamaha YA-6
          77 Suzuki TS-185
          • KA1J
            • 664
            • Groton, CT
            Larry
            Thanks Larry, I ordered two cans from them. The only PJ1 I could find locally was some lube by that name at the harley dealer.
            Gary
            • Yahman
              • Mar 2008
              • 779
              • Salem, OR
              It's good paint but you want follow the directions, don't spray it at a temp of less than 70F. That includes the temp of the part you are painting.
              Larry
              82 XJ1100
              64 Yamaha YA-6
              77 Suzuki TS-185
