I got my bike running today and it is not quite right. The one and two cylinders seem to be getting the right mixture. but the 3 and 4 seem to be running to lean. those two cylinders are also very hot compared to the 1 and2. Any ideas?
Pilot screw?
sync
Carbs need to be sync'd.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186 -
As long as the carbs are good and clean, floats set, etc, get the pilot screws dialed in first as best you can (i.e. set them all at 2 turns or 2.5 turns, or whatever you feel or know is a good starting point) and then sync the carbs. Once they are sycn'd, then fine tune the screws, and to be exact and proper, check the sync again if so desired. Changing the pilot screw adjustment changes the mixture, which in effect is the same as having a carb open or shut a small, tiny amount, and the re-sync just fine tunes it if needed.Howard
ZRX1200
BTW, ZRX carbs have the same spacing as the XS11... http://www.xs11.com/forum/showthread.php?t=35462Comment
Ok when you say set them at 2 to 2.5 turns is that top or bottom of the thread. When you turn in, does the air start to decrease in the mixture?etc, get the pilot screws dialed in first as best you can (i.e. set them all at 2 turns or 2.5 turns, or whatever you feel or know is a good starting point)'78EComment
"Turns" refers to turns out from lightly seated, so turn them in until they "seat" and then start backing out from there. I thinks mine are at 1.5-2 turns out, check my signature
Someone told me once that when pilot screws are on the front of the carbs (like the XS), they control the fuel whereas when located on the rear of the carbs they meter the air.
So, in a nutshell, the more you turn them out from being seated, the richer you are making your idle/low speed mixture by letting more fuel in.
Hope that helps.Howard
ZRX1200
Just be careful when you tighten them to fully seated, the tips are fragile and can break off and stick in the hole. The trick is to not over tighten them, thus saving you a lot of headache. You might want to pull them out and make sure they are not already broken off while your at it, so our not chasing your tail...'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
Yes, maybe I was confusing when I said "lightly seated" and then referred to "seated" later in my last post. Over tight is no good for pilot screws.Howard
ZRX1200
Also, check your petcock operation. Is your petcock fully opening eiht the vacuum? Have you tried on Prime. 3 and 4 are fed from the same petcock, so all else being equal, most likely the petcock is not giving good flow.Life is what happens while your planning everything else!
78 XS750Comment
That could be it also. the petcock operating the 3 and 4, was leaking very slowly at first, but seemed to stop. (huh?) But i have a feeling that the sync is way off also. I got it going alot better with my ear and burning my hand alot, but its still way off. I built the vac gauge last night and gonna try giving it a whirl tomorrow.Also, check your petcock operation. Is your petcock fully opening eiht the vacuum? Have you tried on Prime. 3 and 4 are fed from the same petcock, so all else being equal, most likely the petcock is not giving good flow.'78EComment
where to get new pilot screws?
So before i bothered to sync my carbs i wanted to make sure my pilot screws weren't broken, indeed 3 out of 4 are. So after mother f'ing for awhile i got on here and looked up to see ideas where to get new ones. Bikebandit wants $40 hah! I tried to see if george fix would sell some, but he said he couldn't. anymore ideas?'78EComment
Might as well buy rebuild kits. Are the tips of the needles stuck down in the holes?Nathan
Theodore RooseveltComment
oh yeah. i'm working on building that little screw, with drill head tool. Somebody posted about it earlier. should work. http://www.xs11.com/forum/showthread.php?t=31470&page=2'78EComment
Pic
Just scroll down a few posts and there it is...You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake linesComment
