XJ1100 carb float adjustment concern
Originally posted by KA1J View PostPods... I smell pods
LarryInventor of the YICS Eliminator. Want one? Get it here.
82 XJ1100
80 XS1100G (Project bike)
64 Yamaha YA-6
77 Suzuki TS-185
I would say vertical. Also, I would think that you could disconnect the tube from the carb, drain out a little fuel from the carb and any residual fuel in the tube, hook the tube back on with the other end open and elevated, and that should fill the carb to the point where the float stops it (with a fuel supply hooked-up). Maybe they tell you to run the bike to take care of any differences due to uneven evaporation or in case you hit some bumps on your last ride...or maybe Yamaha knows all about leaking fuel float valves!Last edited by skids; 05-12-2011, 07:09 PM.Skids (Sid Hansen)
Somewhere on U tube
There is a video showing how to remove the carbs in under 2 mins. Also there is one putting them back in nearly as fast... Ask 3-phase what he called it for a good search...You can't stay young forever, but you can be immature for the rest of your life...
Drilled airbox
Tkat fork brace
Hardly mufflers
late model carbs
Newer style fuses
Oil pressure guage
Custom security system
Stainless braid brake lines
Planedick, I recall those vids, and who made them. Good info for sure, but as I understand it, the XJ with the stock airbox makes XS11 airbox carb removal and replacement seem like legos.Life is what happens while your planning everything else!
Originally posted by DGXSER View PostPlanedick, I recall those vids, and who made them. Good info for sure, but as I understand it, the XJ with the stock airbox makes XS11 airbox carb removal and replacement seem like legos.
The XJ airbox sucks!
LarryLast edited by Yahman; 05-13-2011, 09:44 AM.Inventor of the YICS Eliminator. Want one? Get it here.
82 XJ1100
64 Yamaha YA-6
77 Suzuki TS-185
LarryRob
82 XJ1100
Stock..With a few cosmetic changes.
Current Project..Dad's 81 1100 Special
http://s727.photobucket.com/albums/ww272/RiderXJ/
Originally posted by XJ Rob View PostNot true!! I can have the carbs off my XJ in less than 15 minutes. It take a few extra minutes to get them back on but it's not really not bad.
My bike needed jet work when I got it. There was no way I was going to take the carbs off and back on a number of times to get the jetting right, so the airbox had to go.
82 XJ1100
64 Yamaha YA-6
77 Suzuki TS-185
I like that jig so much that I plan on making one of my own. I have farted around so much trying to make something similar. If you get everything right at this stage it will not be far off when the carbs are installed. The bike will have the same float height running or not and level is level whether it is on the bike or on the moon. Congrats on a cool idea!2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
