XJ1100 carb float adjustment concern
  • KA1J
    • 664
    • Groton, CT
    Originally posted by Yahman
    Show off!!!
    Larry
    Pods... I smell pods
    • Yahman
      • Mar 2008
      • 779
      • Salem, OR
      Absolutely!!! I wasn't about to put that mess back together after I finally got it apart.
      Larry
      82 XJ1100
      80 XS1100G (Project bike)
      64 Yamaha YA-6
      77 Suzuki TS-185
        I would say vertical. Also, I would think that you could disconnect the tube from the carb, drain out a little fuel from the carb and any residual fuel in the tube, hook the tube back on with the other end open and elevated, and that should fill the carb to the point where the float stops it (with a fuel supply hooked-up). Maybe they tell you to run the bike to take care of any differences due to uneven evaporation or in case you hit some bumps on your last ride...or maybe Yamaha knows all about leaking fuel float valves!
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          Somewhere on U tube
          There is a video showing how to remove the carbs in under 2 mins. Also there is one putting them back in nearly as fast... Ask 3-phase what he called it for a good search...
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
            I'm sure everything will turn out fine using your jig. It just might not be necessary. You have it, so use it.
              Planedick, I recall those vids, and who made them. Good info for sure, but as I understand it, the XJ with the stock airbox makes XS11 airbox carb removal and replacement seem like legos.
              • Yahman
                • Mar 2008
                • 779
                • Salem, OR
                I've worked on the Standard, Special and XJ, and in my book there is no comparison...
                The XJ airbox sucks!
                Larry
                82 XJ1100
                64 Yamaha YA-6
                77 Suzuki TS-185
                • XJ Rob
                  • Apr 2009
                  • 161
                  • Kimball, Michigan
                  Larry
                  Not true!! I can have the carbs off my XJ in less than 15 minutes. It take a few extra minutes to get them back on but it's not really not bad.
                  Rob
                  82 XJ1100
                  Stock..With a few cosmetic changes.
                  Current Project..Dad's 81 1100 Special
                  http://s727.photobucket.com/albums/ww272/RiderXJ/
                  • Yahman
                    • Mar 2008
                    • 779
                    • Salem, OR
                    I'm not saying it's impossible to work on, just that my old hands don't function that well anymore. When it came to dealing with the XJ airbox, my hands threatened to go on strike.
                    My bike needed jet work when I got it. There was no way I was going to take the carbs off and back on a number of times to get the jetting right, so the airbox had to go.
                    Larry
                    82 XJ1100
                    64 Yamaha YA-6
                    77 Suzuki TS-185
                      • 3193
                      I like that jig so much that I plan on making one of my own. I have farted around so much trying to make something similar. If you get everything right at this stage it will not be far off when the carbs are installed. The bike will have the same float height running or not and level is level whether it is on the bike or on the moon. Congrats on a cool idea!
