I've balanced my carbs on a jig so that they are dead level in all directions
Here's how I leveled the carbs:
Carbs on the jig. Note the bulls eye level with washer below on top of #2 carb
How I adjust so the bulls eye level is centered (the rear two feet are also bolts and are adjustable)
How the bulls eye level looks before leveling
What the bullseye looks like when the carbs are made level.
With the carbs squarely fixed, I'm finding some of the fuel levels were as much as 7-8 mm too high in the sight tube. It says in the manual to slightly bend the tab to adjust the float level. All of the tabs were almost parallel with the metal connected to the floats. It was hard to get anything in there to bend the tab but finally I did, The metal is pretty thick and does not want to bend. Finally after bending the heck out of the tabs I get the level to be 3mm below the carb mixing chamber edge as shown in the manual.
Problem is the manual says to bend "slightly" the tab & I've had to really bend them way down, it's almost like the valve should have been 1mm or so longer instead. I measured the old needles and they are the same dimensions as the new replacements, just the rubber tip is now new.
This is the float from carb 1 and I've bent all the tabs this far upward from flat and while carbs 2,3 & 4 now have the fuel level at the proper place in the sight tube, this tab for #1 needs to be yet more bent to drop the level another 3mm. I'm afraid more may break it.
It doesn't seem right that these floats would have to be adjusted so much to get the fuel to be at the proper sight level marks. Am I doing the right thing in placing the carbs at true square to ground and making the adjustments from this position? Isn't this an excessive "slightly bending" of the tab?
I can't find anywhere in the manual where it says to adjust the floats dry, much less at 23mm as posts relating to the later XS say to do. I'm holding off on doing further work on these till I get a consensus on what's going on.
Thoughts?
Thoughts?
