front brake switch removal
  • oldbiker648
    • Jul 2003
    • 182
    • Richmond, VA
    Pulling the front master cylinder off my '81G and have a question on the front brake light switch. Is it just a friction fit inside the base of the master cylinder ? I don't want to break it trying to pry the assembly out using a flat blade screwdriver. Last master cylinder I rebuilt was on a XS-650 many moons ago.
    _________________
    John
    78E
    79 SF (2)
    80 G "The Beast"
    81 H "The Dresser"
    79 XS650 II
    82 650 Maxim
    70 DT-1 Enduro
    66 Honda CL-77 Scrambler
    96 H-D Road King
    "The road to hell is paved with good intentions."
  • mxmikie
    • Aug 2008
    • 482
    • Bouse az
    i use a dental pick to push the 2 locking ears in
      SHould be the same as my SH, pull the rubber boot back and look at the bottom, 6-o'clock position, you should see a circular hole. Inside that is a tab that sticks down. Push up on that tab with a small screwdriver, and that should let the switch pull out.
      • oldbiker648
        • Jul 2003
        • 182
        • Richmond, VA
        Thanks, guys, I ended up cleaning the spooge hole and cycling the piston several times with my thumb and it looks like it's working fine, so I didn't have to disconnect the switch. Reassembling to pressure test and check the calipers next.
        _________________
        John
        78E
        79 SF (2)
        80 G "The Beast"
        81 H "The Dresser"
        79 XS650 II
        82 650 Maxim
        70 DT-1 Enduro
        96 H-D Road King
