time to clean the spooge
-H. Ford -
do one calliper at a time.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
hey don't know if i need them yet but do you know where i can buy the new pistons? are the front and rear pistons the same on my special?1979 XS1100SF 37000km
Green Dyna Coils
Stainless Brake Lines
1973 CB100
kevXSComment
Brake Cleaning tip
For anyone that is going to mess with your front Brake Cylinder, Take your fuel tank off first. Brake fluid eats paint, you can ruin the finish on your bike if you get some on your tank. If you do get some on your tank, wipe it off immediately, and wash it off with soap and water. I had a permanenty mark in the paint job of a 76 Honda 750 Super Sport from contact with brake fluid.
BlindogSmokinComment
Hvc cycle on ebay sells the ss piston for about 25 each.Nathan
Theodore RooseveltComment
I would seriously doubt
you need new pistons - even if rusty in the back that doesn't affect operation and sides are likely ok...they are avail both here and ebay.
I know the front caliper is different on specials but piston? dunno.
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
thats good to hear, i can't find anything on ebay anyway, anyone have the link to the HVC page on ebay? its annoying that you can't use the ebay search to find sellars like (georgefix and HVC)1979 XS1100SF 37000km
Green Dyna Coils
1973 CB100
kevXSComment
never mind, found em
http://stores.ebay.ca/HVC-cycle
thanks for all your help guys!
XS11.com is the BEST SITE EVER1979 XS1100SF 37000km
Green Dyna Coils
1973 CB100
kevXSComment
ebay search
You can search for sellers - click ADVANCED to the right of the search term window and in left pane click by seller - there is an option for close matches if you are unsure...
Or you can click on the upper right corner of the main ebay screen on "Community" and search by name in there.1980 XS850SG - Sold
-H. FordComment
piston out
so i got one of the pistons out so far with the grease gun method. now i guess i clean up the piston and sleeve with a brillow pad or something?
it doesn't look too bad.
how do i get all the grease out of the passages? will it be a problem if there is still trace amounts of grease left in the caliper?
sorry for the million questions, not an experienced mechanic at all here . . .1979 XS1100SF 37000km
Green Dyna Coils
1973 CB100
kevXSComment
if u havent done so already,
remove the o ring that sits inside the calliper,
remove as much grease as u can with a rag, then spray
carb/brake cleaner inside the calliper and its
orifices to remove the remainder of the grease,
rinse well in hot soapy water, also only clean the
o ring with water or brake fluid, anything else will cause
the rubber to swell.
when putting the o ring back in the calliper smear it with
brake fluid or rubber grease only.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
so i've got the brakes back together and bled them but my lever is still a bit spongy.
i have not bled the master cylinder i was only bleeding the calipers, can anyone tell me how to bleed the m/c without removing it from the bike?
i've also read about using an oil can to pump fluid in through the bleeder screw. this seems like the best method to me and i would not have to bleed the m/c using this method correct?Last edited by kevxs; 05-09-2011, 01:36 PM.1979 XS1100SF 37000km
Green Dyna Coils
1973 CB100
kevXSComment
