1979 XS1100SF color coded wiring diagram needed
  • Levi
    • Apr 2011
    • 8
    • Pittsburgh, PA
    Hi there, I am new to this forum and to mechanical repairs in general. My headlight and tach/speedometer lights aren't coming on anymore. I've been searching through this site and I thought I found a wiring diagram that had been nicely color coded for the 1980 XS1100SF but I can no longer find it. Can anyone tell me if they've seen it? Thanks.
    Levi
    1979 XS1100 Special
    Previously owned 1979 XS750 Special
    Not sure of that, but two places I would start looking at is fuse box, and main switch.
      Hi Levi and welcome,
      yeah, I've seen that colored wiring diagram too. Throw enough code words at the search button and it'll hopefully show up.
      The headlight/gauge lights only turn on automatically at startup if the alternator is working.
      The tach works off the alternator too.
      If lights and tach have both quit, suspect the charging system.
      If the tach still works, check the fuses and wiring connections.
      • latexeses
        • Jun 2008
        • 1491
        • California
        Didn't 3phase post that schematic?
        url]http://www.xs11.com/forum/showthread.php?t=18796&page=3[/url]
        It's for an 80 not a SF.
        Everything on hold...
        • latexeses
          • Jun 2008
          • 1491
          • California
          Try this instead...
          • forexbob
            • Aug 2010
            • 109
            • Calgary
            It's supposed to be cold and rainy on Sunday. (At least it's not snow) I'll make one up for the 79SF. I use the Service manual and colour match the wires as best I can.
            If the weather turns sour on Fri or Sat and I can't work on the bike, I'll do it earlier.
            Hopefully you can wait till then.
            Bob
            • Joab
              • Aug 2010
              • 472
              • Ozark, Alabama
              As another fellow with SF wiring issues, I thank you beforehand for going through the trouble of creating the color diagram. If your ever passing through the middle of nowhere, Alabama, lunch is on me!
              Joab
              "If nothing else, it will be interesting..."
              ______________________________________________
              1979 XS1100SF
              1972 XS2 650
              Ozark, Alabama
              • Mr.Bill
                • Aug 2009
                • 118
                • Clarksburg Maryland
                1979 XS1100SF.
                "You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
                • Levi
                  • Apr 2011
                  • 8
                  • Pittsburgh, PA
                  Thank you all for your help! I was hoping that the headlight/speedo/tach light issue was isolated, but when I started the bike up recently my right turn signal (as well as the turn signal indicator on the dash) wasn't working either. The indicator light on the dash works when the left signal is going. Looking at the wiring diagram I see that there are both a right and left turn signal indicator, but my bike only seems to have one indicator light that is used for both right and left. Is there something that I'm missing here?
                  Levi
                  1979 XS1100 Special
                    • 8962
                    Those Clymer wiring diagrams do have a few errors, most of it is right though.
                    • forexbob
                      • Aug 2010
                      • 109
                      • Calgary
                      Mr Bill, I looked for those, obviously not diligently enough, before I made mine.
                      Those look good but mine are...well, ya those look good
                      The only advantage I have with mine is that I did it in InDesign using layers for the different colour wires. I can isolate each colour. And for a rookie like me and with my eyes, that really helps. I tried to figure out how to get that to work in a PDF, but no joy. Ideas on that anybody?
                      Bob
                      • forexbob
                        • Aug 2010
                        • 109
                        • Calgary
                        For What It's Worth (Isn't that a song
                        .jpg
                        Colour Wiring Diagram 79SF
                          - - - - Looking at the wiring diagram I see that there are both a right and left turn signal indicator, but my bike only seems to have one indicator light that is used for both right and left. Is there something that I'm missing here?
                          Hi Levi,
                          most likely what you are missing is that one of those dreaded POs swapped in the indicator console off an XS650.
                          Not to worry, if it's wired up properly it'll work just fine.
