cam chain tensioner
  • bcknblkbird
    • Mar 2009
    • 124
    • jonesville nc
    cam chain tensioner
    just bought one off a 92 vmx12. according to the list on this subject it will work right? just need to elongate top hole. make gasket. thanks!
    • 8893
    Should be the correct one, might not even need to ream one of the holes.
    • CatatonicBug
      • 6117
      • Clinton, UT
      Also no need for a gasket. Just use RTV and you'll be fine.
      • Toolmaker Tim
        • 671
        • South Bend, Indiana
        When I put mine on it was plug and play. No alterations. +1 on the RTV, just make sure the socket head cap screws are not too long and you should be golden.
        1979XS1100SF
        K&N's and drilled airbox
        Jardine 4in1
        Dunlop Elite 3's
        JBM slide diaphragms
        142.5 main jets
        45 pilot jets
        T.C.'s fusebox & SOFA
        750/850 FD mod.
        XV 920 Needle Mod.
        Venture Cam Chain Tensioner
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          VMAX CCT's are plug and play, the vision tensioners need to be moded a little...
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
          • bcknblkbird
            • Mar 2009
            • 124
            • jonesville nc
            cam chain tensioner
            does it matter which hole goes on top? i.e the rachet device on bottom.thanks
              Not used the Vmax one but typically, it will only fit one way. If you put it in upside down, the bolt hoels will not line up.
