Finally getting around to doing some serious work on the XJ1100. Bought it in November with 19K on the odometer & I only put around 200 miles on it before winter storage. I'm getting a set of Jardine Spaghetti exhausts prepped & ready to be ceramic coated. When I removed the MAC 4-1 that came with it I found #2 cylinder was running way lean.
I know the carbs were way out of adjustment because the idle adjustment screws on 2&3 had been tightened down as far as they could go. I don't have a compression tester but I'm hoping the valves in #2 are not damaged. The PO didn't put any exhaust gaskets in when he installed the MAC 4-1. Sweet...
To the hopeful, it sure had scary power last year even when horribly maladjusted.
Thoughts?
Thoughts?
