Installing the head: 12 washers and 12 acorn nuts?
  • LoHo
    • Sep 2002
    • 1342
    • Fresno, CA
    Hey guys, my manual says to replace the twelve washers and acorn nuts on my 1980G...is it possible that the four interior acorns don't have washers? I think that I only took eight off, but the Clymer's says twelve. I got more washers at the wreckers, but I want to be sure that I need twelve washers for the twelve acorns. I'd hate to snap something off because I fixed a problem that wasn't a problem.
    Hey Loho,
    From the 80G parts fiche!
    15 90201-11597-00 WASHER, PLATE 12
    16 90179-10277-00 NUT 12
    Looks like you need a dirty dozen!
      Yup just had my head off, there is 12 if each.
      • LuckyEddie
        • 166
        • Middleville, Michigan
        Head Washers
        Look a little closer. Mine was the same way. The washers are there, but look like a boss. It took some more cleaning and a bump with a drift to knock them loose.
        LuckyEddie
        1980 XS1100LG Midnight special
        1982 XV750J Virago
        1976 GL1000
        1978 GL1000 Supercharged
        1981 XV920RH (chain drive)
        • LuckyEddie
          • 166
          Head Washers cont.......
          As an after thought, you can check for the washers by using a magnet, washers are magnetic, the head is not.
          LuckyEddie
          1982 XV750J Virago
          1976 GL1000
          • LoHo
            • Sep 2002
            • 1342
            • Fresno, CA
            Naw, Lucky, I'd had the head off and worked on the valves and a bunch of other crap, so them being stuck on was not an issue. The plastic compartment storage into which I'd put the parts as I took them off was short four, but I pulled the head months ago, so I must have misplaced them, although I thought I was careful. I searched all of the usual suspects to no avail. I'll probably find them when I go searching for one of the four 12mm sockets I can never find....
              Them Dang garage gremlins! I hate those things, never do see them though...
              • LoHo
                • Sep 2002
                • 1342
                • Fresno, CA
                Well, I got her all back together...finally. Cranked her over and she cranks smoothly...no spark...again....
                  What did you find as the problem last time?
                  Do you have any pics of the piston/combustion chamber after cleaning them up?
