tank vent leaks
    • 5049
    still a lot of work, and you have to get all the gas flushed out of the tank before doing this so you don't blow yourself up!
    I realize that brazing or soldering is not the same as welding, but welding on empty, even "cleaned" tanks causes explosions.
    • jwhughes3
      • 2798
      • Home of the Alamo
      fill it with water
      and no explosions.
      john
      '81 XS1100H - "Enterprise"
        I have found that after emptying the tank and letting it dry out I put a couple cups of denatured alcohol in it and shake it around good for a bit, dump it out and them put eater in it and shake then dry. Most of the time you can't smell gas at that point if you can do it again.
        I have never had a problem after doing that, never had one light/explode on me.
