will the CARB DIAPHRAGMs form the 1979,78 work in the 1980,81 bodeies?
CARB DIAPHRAGMs
CARB DIAPHRAGMs
1980 midnight xs1100 Rebilt cosmetically
1980 midnight xs850 bagger
1980 Special xs1100 (all apart)
1979 special Special runner
2011 street glideTags: None -
Diaphragms
If you are talking about the entire assembly, the diaphragm and slide body,the answer is no. As for the diaphragm alone, I don't know. Are you trying to rebuild your existing slides or replace the whole assembly?1979XS1100SF
K&N's and drilled airbox
Jardine 4in1
Dunlop Elite 3's
JBM slide diaphragms
142.5 main jets
45 pilot jets
T.C.'s fusebox & SOFA
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain Tensioner -
As Tim said, the diaphram/slide won't swap, but you can swap just the diaphram. A bit tricky to get off the old slide and on to the new, but doable...Fast, Cheap, Reliable... Pick any two
Diaphragm Swap
Thanks Steve, I was ready to try to see if they were swappable by turning one upside down on a carb body. I guess I could have just laid one on top of a 78/79 slide assembly. By the way, how do you get them apart?1979XS1100SF
Jardine 4in1
Dunlop Elite 3's
142.5 main jets
45 pilot jets
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerComment
Pictures
Well, if pictures are worth a thousand words, there's 8000 words!
Thank you Rasputin
1979XS1100SF
Jardine 4in1
Dunlop Elite 3's
142.5 main jets
45 pilot jets
750/850 FD mod.
XV 920 Needle Mod.
heres a link to a method of changing the
rubbers over, if they do swap over works well.
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Fortunately I don't need to do a change right know. I have a spare set of 78/79 slide assemblies. I also have a set of 80/81 slides that came with a parts bike. The PO had grafted a 81SH carb into a rack of 78/79 carbs with perdictable results.
1979XS1100SF
Jardine 4in1
Dunlop Elite 3's
142.5 main jets
45 pilot jets
750/850 FD mod.
XV 920 Needle Mod.
good
Thank you for the replply.you guys are grate1980 midnight xs1100 Rebilt cosmetically
2011 street glideComment
Actually, I've swapped them without removing the plastic ring or modifying anything. I simply pulled them off (carefully, as not to tear it), then 'stretched' them to reinstall. That's where it gets tricky, but careful working at it can get them back on. Use a little WD40 for lube, it helps...Fast, Cheap, Reliable... Pick any two
How does one tell the difference between 78/79 and 80/81 slides? I have a box with 8 sets and know that there is one set of each.
Thanks1995 KZ100P
Pods, jets, pipes, cam adjuster, oil cooler
1977 Ironhead - custom build
Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.Comment
if u click on the link in my post above, it shows a pic
of the later model slides, its been ages since ive seen the early
model ones and cant remember what they look like.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
The '78-79 slides are smaller in diameter than the later slides, but there's other differences too. The '78-79 have a plastic retainer for the needle jet that's held in with a C-clip and an adjustable needle, while the later slides have a non-adjustable needle jet that's covered by a round metal plate held in with two screws. If you see screws, it's the later type.Fast, Cheap, Reliable... Pick any two
I replaced my four diaphragms easily without having to cut the top off. It's so simple to do that I would recommend doing it in the way described here. I personally don't like the idea of cutting the tops off because it will affect the integrity of the component and the weights of each slide assembly may vary afterwards:
I bought my diaphragms from this US seller and they fitted easily. You definitely need lighter fluid as a lubricant... it's the best stuff for it. My old diaphragms were torn and pin-holed. The new ones made a huge difference to the running of the bike.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
