Has anyone here replaced their front brake M/C with one off of a Venture or VMax? I am seriously considering the hydraulic clutch mod and changing both brake and clutch levers to that setup would make them match and also fix my ugly oxidized brake resevoir that came on the 79F. I want to be sure they will work before I try to sweet talk SWMBO into letting me buy the parts for the mod.
XVZ1300 Master Cylinders
1979XS1100SF
K&N's and drilled airbox
Jardine 4in1
Dunlop Elite 3's
JBM slide diaphragms
142.5 main jets
45 pilot jets
T.C.'s fusebox & SOFA
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerTags: None -
hi tim,
do u know the bore size of the m/c?pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url] -
Yup, bore size is what is gong to matter.Nathan
Theodore RooseveltComment
M/C Bore Size
I am guessing you are refering to the bore diameter of the Venture/VMax M/C. I will have to look that up.1979XS1100SF
Jardine 4in1
Dunlop Elite 3's
142.5 main jets
45 pilot jets
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain TensionerComment
Correct. The bore of the master cylinder.Nathan
M/c
Nathan, I just went back and reread Jesse's hydraulic clutch thread, and he was going to change to a FJ master. Jesse also mentioned the VMax masters which is probably where I got the idea in the first place.1979XS1100SF
Jardine 4in1
Dunlop Elite 3's
142.5 main jets
45 pilot jets
750/850 FD mod.
XV 920 Needle Mod.
if it helps the stock bore is 11/16 and the stock
bore on my aussie rh is 5/8 the same as the midnites but
running to both front callipers, so if the m/c ur looking at
has either sizes of these bores u should be sweet to go.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
