Installing lower bearing on steering stem??
  • tri650
    • Feb 2010
    • 89
    • St. Louis, MO
    I have new steering stem bearings and need to install the lower on the steering stem. Obviously it flanges at the end so how are these typically installed - pressing them or beating them in?
    _____________________
    78 XS1100 - mainly stock
    I used the old race and tapped it into place.
      • 8736
      Take the inner part of the old lower bearing and cut a slot in it top to bottom. It will now fit exactly upside down on the new bearing and can be used to hammer the new bearing on the stem. The slot is so it won't also get pressed on the stem. A piece of pipe or an old fork tube might come in handy to hammer it down. Don't forget to install the new grease seal before the bearing goes on.
        • 7808
        As always, there's a tool for that. You need a race driver.
        You can probably do the job with a brass drift, if you're careful.
          Yeah you can buy that, but what fun is having the right tool....
          • petejw
            • 2269
            • sydney australia
            a socket slightly smaller also works well.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              • 8736
              Pretty sure he meant install bearing on TT stem, not install race.
              • tri650
                • Feb 2010
                • 89
                • St. Louis, MO
                Bearing - not race
                Correct - I have the upper and lower race already installed. Want to get the lower bearing on the stem. Thought about a piece of pipe that would fit over the stem and rest against the bearing and then wack it with a rubber mallet to force it down. Concerned I might damage the bearing - any thoughts.
                • petejw
                  • 2269
                  • sydney australia
                  i shouldve read it better,
                  u can use a piece of pipe but u want it to touch
                  the inside of the bearing only or as phil and nate stated cut the
                  inside of the old one and place the pipe over that one
                  to hit the new one into place.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                  • XS1100 Newbie
                    • Jun 2009
                    • 1106
                    • Battle Ground, Washington
                    I stuck my triple tree in the freezer overnight, and then heated my bearing in oil, and then just dropped it on. Don't take the triple tree out until the bearing is hot. Let it sit for quite a while afterwords to let it come back to room temp, the grease with a needle point.
                    1980 XS1100LG Midnight
                    1991 Honda CBR1000F Hurricane
                    A cold beer and another one!
                      The lower is supposed to be pressed on, but you can install it with a BFH with a little care. Don't pound on the outer race at all, and put something under the stem on the lower tree so you don't tweak the tree. Don't waste your time with a rubber hammer; a dead-blow hammer would be better if you have one, but the bigger the hammer the better/faster it will go on.
                      • tri650
                        • Feb 2010
                        • 89
                        • St. Louis, MO
                        Thanks for the suggestions. I will try the freeze/hot oil treatment. I worry about beating the bearing and will do that as a last resort.
                          • 7692
                          I used the "old race and pipe" to replace bearings. Works every time, and will NOT hurt the bearing. I bought an 18" X 2" pipe (IIRC) from Ace, and use it to beat on. The freeze and hot will also work, but take care with the new seal!
                          • b.walker5
                            • Feb 2009
                            • 1745
                            • Invercargill, New Zealand
                            You're 'on to it'. Thats the best way if you dont have a press. Beating it with pipes and such works but a 'gently, gently' approach, and patience is needed.
                              Not all Race Driver are tools
