I was out fiddling with the bike yesterday and i now have a couple of problem.
I found vacuum leaks on #1 and 2 intake boots. Do i have to remove the carbs to tighten these down and are there suppose to be gaskets between them and the head. I also took temperature readings of the headder pipes after it was warmed up and noticed that 2-4 were around 300f while #1 was barely at 100f what could cause this?
Thanks in advance for any suggestions
