Intake boots
  • lancelot455
    • Sep 2010
    • 174
    • Regina,Saskatchewan,Canada
    Intake boots
    I was out fiddling with the bike yesterday and i now have a couple of problem.
    I found vacuum leaks on #1 and 2 intake boots. Do i have to remove the carbs to tighten these down and are there suppose to be gaskets between them and the head. I also took temperature readings of the headder pipes after it was warmed up and noticed that 2-4 were around 300f while #1 was barely at 100f what could cause this?
    Thanks in advance for any suggestions
    82 XJ1100
    Canada
    2006 V-Star 1100 custom
  • 1981XS
    • Nov 2009
    • 30
    • Fargo ND
    where are the vacuum leaks at? Im assuming at the head, But what I found on mine the other day was that the boots were actually cracked all the way through, if you can get a allen wrench in there you can tighten them down alittle more, im replacing my boots at this time and i had a heck of a time so i just pulled the carbs out, as far as gasket goes, Im going to use some RTV Gasket maker, I use the brand "the right stuff" Made by Permatex, that product is really good for pretty much any gasket on these bikes
    Abe
    1981 XS1100H Venturer #458
    poor thing has about a dozen nicknames depending on the day we are having......lol
    My Parents Told Me I Could Be Anything I Wanted.....So I Became An @$$hole
      There was no gasket on that surface from the factory, but some folks have added one (using a thermostadt gasket from an older model ford, IIRC). I used "The Right Stuff" on mine as well, and use it on most other places where gaskets are used on the bike.
        There was no gasket on that surface from the factory...
        Sorry 'bug, but there is supposed to be a gasket there; I've found them on every one I've pulled off...
        But a light smear of RTV will take care of it.
        • lancelot455
          • Sep 2010
          • 174
          yes it's leaking at the head.i tightened the #1 but can't get at the #2 looks like i'll be pulling carbs tomorrow
          82 XJ1100
          Canada
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            I used Yamabond on mine and they've stayed sealed just fine. It really doesn't need much, but make sure it's something made for high temps, cause it does get a little hot there where the carb holders attach to the head.
            • 1981XS
              • Nov 2009
              • 30
              • Fargo ND
              ah the joy of pulling carbs......if its any comfort after the 4th or 5th time removing and replacing you start to develop a system
              Abe
              • Incubus
                • 1003
                • Austin TX
                Once you hit 25 or 30 times you start timing yourself. In my prime I got to "running bike to carbs on the bench" in under 13 minutes....
                Patrick
                XS11F (Incubus, daily rider)
                1969 Yamaha DT1B
