850 and 1100 same brakes system?
  • redbone
    • Oct 2007
    • 244
    • Waynesboro pa
    anyone know for sure if the brake system on a 1980 850 special and a 1980 1100 special are exactly the same? found a place that makes a 4 line replacement for 850 special and wonder if they'll fit the 1100. biggest issue would be length and banjo angles i would think. any info appreciated.
    redbone.
    testing 1-2-3
    1980 1100 mns
  • crazedfooter
    • 33
    • Bettendorf, IA
    placing my order today for a set, i am fairly certain they are the same size, length etc from my rough measurements off my 850. if you want to hold off a week or so i will get them mounted up and give ya the final word though so you won't have any issues.
    i have test fit the upper line and part numbers on the upper are the same, calipers are the same, splitter is the same but the pn on the lower 2 are different. rear rough measurement/appearance looks about the same as well.
    nick
    • b.walker5
      • Feb 2009
      • 1745
      • Invercargill, New Zealand
      redbone.
      Same thing. Check here for part number comparisons and what other models have the same parts.
