Alright so I was cleaning up my carb intake boots in preparation to put them back on soon and I found one of the vac nipples can be pulled out. I know someone had this issue recently but can't find the thread. So I am looking for suggestions for permanent solutions to fix it. Boots are basically new so I won't replace them.
Carb Boot Nipple
Carb Boot Nipple
Theodore RooseveltTags: None -
JB weld gets soft in gas.Nathan
Theodore RooseveltComment
-H. FordComment
Don't want to derail your thread, Nate, but I have a question as well. PO removed the octy, and the middle left carb has no vacuum cap on it. Is there a possible reason, or is it just MIA? Bike runs fine, so I haven't taken the time to replace it. Probably sucking in all kinds of dirt (damn oklahoma dustbowl).
As far as your concern, I agree with Bug and would use black RTV.Richard
'79 XS1100SF "Phantom Stranger" full fairing w/radio and cd player, H-D Roadking trunk, everything else stock
'02 Honda VTX1800CComment
It's messing up your carb sync and your mixture, and eating up your cylinder and needs to be plugged asap!Don't want to derail your thread, Nate, but I have a question as well. PO removed the octy, and the middle left carb has no vacuum cap on it. Is there a possible reason, or is it just MIA? Bike runs fine, so I haven't taken the time to replace it. Probably sucking in all kinds of dirt (damn oklahoma dustbowl).
yeah go to NAPA and get some vacuum caps and get that thing plugged and resync. Think, you are sucking in unaltered air through that hole....Don't want to derail your thread, Nate, but I have a question as well. PO removed the octy, and the middle left carb has no vacuum cap on it. Is there a possible reason, or is it just MIA? Bike runs fine, so I haven't taken the time to replace it. Probably sucking in all kinds of dirt (damn oklahoma dustbowl).
I have never had JB weld stand up over time in petroleum products, and I would NEVER use it to fix a float post. Rtv is so far looking like the winner though, or nipple clamps.....Nathan
Hi Okie,
what a great bike the XS11 is! It even runs fine with one vacuum cap missing. (Or with one air pod missing, as I know from personal experience. But that was in B.C.'s rain cleansed air, not the Okie dust bowl.)
Thing is, there's extra air coming in with that nasty abrasive dust and if the PO adjusted the carbs rather than install the missing vacuum cap, you may need to readjust when you cap it off again.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Thanks guys, I have plenty of vacuum caps in my tool box from my carbureted racing days, and will put one to good use. Come to think of it, she does run like she is missing at lower rpm's, but when above 3,000, hold the f on! Maybe vac cap will clear that up and help fuel mileage? I shall find out.Richard
nipple clamps?
Sounds too painful!!
JohnJohn is in an anonymous city with an Alamo (N29.519227,W-98.678980)
'81 XS1100H - "Enterprise"
"Not all treasure is silver and gold"Comment
Only if the chain is too short?
Yeah, the one of my new (at the time) carb manifold nipples rotated when I was trying to take off the hose with pliars. I just pushed it back into position and all is well. It seals well and is tight enough that it wont fall out.Skids (Sid Hansen)
That carb port is for your vac advance if your talking about the carb itself.. If the advance is plugged on the manifold ports it will not work right. Just sayingOriginally Posted by XSive Okie View Post
- - - PO removed the octy, and the middle left carb has no vacuum cap on it.79SF
XJ11
78EComment
