i need help to get my bike going or im going to scrap it!
  • GTXS1100
    • Jun 2010
    • 224
    • Columbia MO
    So i have an 80 xs11 and i cant get the bike to charge the battery. the battery was new last year and it holds a charge just fine. have tried different alternator and regulator off of another bike don't know if any of them are good. does someone have any pinpoint test to help me narrow down and rule out my problem parts.
    80 XS1100G Black Betty (Daily Driver)
    79 XS1100SF (Buddys Project)
    82 XJ750 Maxim (Fathers Bike)
    81 CB750F SS (Buddys Project)
    06 GSX600F Sold! (Was Mine)
    81 XS1100 Failed Bobber Project (Mine)
    81 XS1100 Parts (Mine)
    Grip it, Rip it, and Stick it!!!
  • dezmitchell
    • Jun 2010
    • 51
    • vegrEVILle AB
    do what i did CHEAT!!!! load it up in the truck and ship her off to a good shop.
    1980 XS standard With Pods and Harley mufflers
      Does the tach work?
      • GTXS1100
        • Jun 2010
        • 224
        • Columbia MO
        but what did they find wrong with it. and what did it cost you?
        • dpotter58
          • Aug 2004
          • 1846
          • Southern Maryland
          no shop time. As was asked, does the tach work? Start by telling the group that then someone will suggest the next step
          1980 LG
          1981 LH
          • GTXS1100
            • Jun 2010
            • 224
            • Columbia MO
            i dont know i took the whole cluster off. didnt like the way it looked
            • dpotter58
              • Aug 2004
              • 1846
              • Southern Maryland
              The charging system drives the tach and thats a common place to start when troubleshooting. can you plug it back in or did you booger the wiring harnes?
              1980 LG
              1981 LH
              • GTXS1100
                • Jun 2010
                • 224
                • Columbia MO
                it used to work without it. i still have it. if i plug it back in what kinda testing can i do to find out what the problem is?
                • dezmitchell
                  • Jun 2010
                  • 51
                  • vegrEVILle AB
                  Dont know and dont care ....just droped bike off on friday when it comes down to paying or not riding i will pick paying everytime.
                  • dpotter58
                    • Aug 2004
                    • 1846
                    • Southern Maryland
                    The tach gets the signal from the charging system. If the tac works you are charging. Some bikes (not sure which ones dont) have a diode in the harness that can go bad and cause you problems. Do a search for diode and look at the tech tips for charging system. Sometimes its as simple as a bad connection.
                    You can work your way through most issues with these bikes if you try. They are very user friendly as far as repairs go. Could be someone in your area with an 11 can help out
                    What year and style bike do you have?
                    1980 LG
                    1981 LH
                    • GTXS1100
                      • Jun 2010
                      • 224
                      • Columbia MO
                      i know they are easy to work on im just running into a wall. i was wondering if there were some test it can go threw with a test light and my meeter of proper voltages and things to isolate the problem
                      • GTXS1100
                        • Jun 2010
                        • 224
                        • Columbia MO
                        where are the diodes so i can check them out?
                        • cywelchjr
                          XS-XJ Super Guru(Deceased)
                          • 4450
                          • Sacramento, CA
                          For starters you can't test with parts that you don't know are good.
                          You can start with this tech tip from the tech tips section of the site: http://www.xs11.com/xs11-info/tech-t...eshooting.html
                          You will of course need some basic electrical tools, a digital multimeter and such. It would also be good to dowload the manuals from Catatonicbugs web site, the link is in any of his posts. You don't need the tach on the bike, it's just one of the indicators of system operation, and not even an accurate one all the time, mine worked fine and my alternator didn't work.
                          One of the other things to check, and you can do so as part of the tech tip, is to check the connector behind the fuse box, the one with the 3 white wires, it can get corroded and melt and that will make it not work, or just get corroded and make it not work. But start out with those checks, and go through the rest of the electrical stuff in the tech tips, it will guide you through a lot of the charging system stuff if you read through those.
                          • Rickrod3
                            • Jun 2009
                            • 721
                            • Oakland, New Jersey
                            Find the member Catatonic bug in his signature he has a link to a manual you can download. in the manual is an electrical section which has check out procedure. Most of of us start with the 3 white wire connector behind the fuse box.
                            This connector is the lines from the alternator.
                            Also if you have not replaced your fuse box consider it now and save yourself some grief.
                            Rick
                            650SF
                            XS1100SG Project bike
                            • dpotter58
                              • Aug 2004
                              • 1846
                              • Southern Maryland
                              I have an 81 special mine was under the gastank look in front of the regulator in the harness you will see a white wire under the tape, mine was looped in the bundle near the reserve lighting device. The diode is in a clear plastic protector kind a thing...
                              1980 LG
                              1981 LH
