XJ11 Caliper rebuild
  • Smash
    • Aug 2010
    • 257
    • Denver, CO
    Going to have to buy a rebuild kit for one of the front calipers on the XJ (the others were re-usable after a good cleaning). Want to confirm that the kits for the SH will work on the XJ before pulling the trigger. Is this correct? Will be buying most likely from Georgefix on ebay.
    Two weeks vacation does NOT make a life.
    His: 2006 Ninja 650R, salvaged, 10k miles
    Hers: '82 XJ1100 44.4k miles
      • 8799
      No, the LH (81 Midnight Spcl.) calipers are the same as the 82 XJ11.
      • Smash
        • Aug 2010
        • 257
        • Denver, CO
        Thanks! Much appreciated.
        • Smash
          • Aug 2010
          • 257
          • Denver, CO
          Alrighty guys, GeorgeFix on ebay doesn't have a rebuild kit for a front caliper.
          Where are you guys finding the seals for the front?
          • Smash
            • Aug 2010
            • 257
            • Denver, CO
            EDIT: nevermind, seems georgefix DOES have a set for the LH!
            • KA1J
              • 664
              • Groton, CT
              Email Len at: info @ xj4ever.com He has OEM and aftermarket front caliper rebuild kits.
              He has most everything else for the XJ line.
              • Smash
                • Aug 2010
                • 257
                • Denver, CO
                Thanks, saved his information. Georgefix had a front kit for $16 shipped for the LH, just bought that.
