XJ11 Caliper rebuild
  • KA1J
    • 664
    • Groton, CT
    I have no idea how well the bike has been maintained till I got it. If the way the carbs were mis-adjusted (idle jets tightened 100% of the way down), I am replacing aging parts before running the bike on the road.
    I'm replacing the brakes, looking for the best price on stainless braid brake lines and want to rebuild the calipers. I found one place selling the REAR Caliper rebuild kit but minus the fluid seal circular retaining circlip & I'd have to reuse the old one. I haven't replaced these before so I have no idea what the circlip looks like or how it's placed.
    Does reusing the retaining circlip sound reasonable and is there any issue removing it or re-installing it in the caliper or wherever it goes?
    Alternatively, suggestions where I can get complete OEM rebuild kits at a good price? AND is there any real benefit to getting OEM over aftermarket?
    Thanks!
    I would say chacal at bikes.com would be your best bet for XJ lines, chexk out c-bug signature for a direct link.
    As tocaliper rebuild kits, 98% of the time all they need is a total disassemble and cleaning and no new parts. So pull it apart first.
    • lancelot455
      • Sep 2010
      • 174
      • Regina,Saskatchewan,Canada
      That's good to know cause after storing mine for the winter and starting to ride this week i noticed that the rear brake is sticking. Looks like i'll be pulling it apart and cleaning it.
      82 XJ1100
      Canada
      2006 V-Star 1100 custom
      • James England
        • 3039
        • North of England
        I reused all three of my clips with no problems. As long as you don't severely distort it when removing it, you should be able to clean it a bit with wire wool and re-use it......
        • jwhughes3
          • 2798
          • Home of the Alamo
          wire wool
          James does that "wire wool" come from these metal sheep?
          http://www.flickr.com/photos/neilt/3351416956/
          John
          '81 XS1100H - "Enterprise"
          • KA1J
            • 664
            • Groton, CT
            Good replies.
            I've rebuilt car calipers before but never a bike. Other than the obvious tears in anything rubber or pitting in the metal piston, is there something in the process I might need to be aware of before I start into it?
            Thanks
              I'd say the main thing to look at is getting the groove the piston seal fits into as clean as possible; at least 90% of the caliper problems reported is caused by corrosion behind the seal. If your bike has high mileage (I'd say 80K miles or more), I would use new seals as they may be worn enough to cause problems, but under that you can usually just thoroughly clean everything and reuse it.
              • KA1J
                • 664
                • Groton, CT
                Mileage is around 20K but whoever owned it before had no conception of how to care for it properly. Ah well, that's my job now & I'm enjoying it. I have to admit it's fun to work on such a beautiful machine.
                If it's not the age & constant exposure to the brake fluid that causes the pitting then it'll probably be OK. I don't see any leakage but I will need to clear out the spooge hole on the MC as there's sticking when the wheel is turned and the bike is pushed.
                It was suggested to me to block off the brake hose port with a bolt and then use a grease gun to the bleeder to pressure out the piston. Since there's three calipers how else might I get the piston out easily with less mess?
                • petejw
                  • 2269
                  • sydney australia
                  hi kaij,
                  tho ive never done it, the grease gun works if u have
                  a seized calliper, if the callipers are working and ur pulling
                  them apart to clean, u can pump the lever til the piston just
                  about pops out and using a pair of multi grips remove the piston the rest
                  of the way, if u want to block the hoses off, clamp a pair of vice grips
                  to the rubber brake hose that will stop any fluid from getting past.
                  on reassemby coat the rubber seals with brake fluid or rubber grease,
                  and prime the master cylinder before attaching to the bike.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  1981 xs1100 RH (aus) (5N5)
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                    Compressed air pops the piston out as well. Less mess, more dangerous. Put something like a wood door shim over the piston and wrap it with rags. That piston will go flying/smash fingers if left to its own devices!
                    • CaptonZap
                      • Jun 2010
                      • 1748
                      • Denver
                      [QUOTE=petejw;318562]hi kaij,
                      QUOTE]
                      Uhh, I wouldn't do that. Gas lines, with no reinforcing braids, you might get away with that, but brake lines have woven cords in them, that when pinched, can be weakened or broken. You can't see it, but the damage is done, and when you do a "for real" panic stop, you don't want the hose to spring a leak where you pinched it.
                      Go ahead, and drain the old fluid, it probably needed it anyway. CZ
                      • petejw
                        • 2269
                        • sydney australia
                        [QUOTE=CaptonZap;318573]
                        Originally posted by petejw
                        hi kaij,
                        QUOTE]
                        hi captainzap,
                        kai stated he was replacing his brake lines in his first post, so that wouldnt be a problem,
                        it was something we used to do on cars when replacing rear wheel cylinders,
                        or removing front callipers,
                        it only needs to be slightly clamped (pinched together) but i understand where ur coming from.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • lancelot455
                          • Sep 2010
                          • 174
                          I am cleaning the rear caliper on my bike and am having a tough time getting the piston seal groove clean. Will a dremel with a brass brush work without damaging anything?
                          82 XJ1100
                          Canada
                            • 3186
                            I found that a toothbrush dipped in Brake fluid loosened the gunk pretty good. The whole dremel thing might work but I would just pick away at it with hand stuff myself. The XJ's are harder to find parts for if you do bugger something up.
                            • lancelot455
                              • Sep 2010
                              • 174
                              Thanks,
                              that's what i am doing now. Should have it back together soon
                              82 XJ1100
                              Canada
