Installed 3 ohm coils, STILL missing in the Philippines!!!
  • hanger10
    • Sep 2008
    • 102
    • Liloan, Cebu, Philippines
    #61
    jets
    Damn!!! One of these days Ill get everything posted in one post!!!! Now, I need to ask should I get idle and main jets???? And, if I do get main jets, what size? Thanx again everyone for all the replies and info!!!
    Smiling in the Philippines
    1980 XS Eleven Special
    Running nicely thanks to this forum!
      #62
      If the mains screw in then they are the right style.
      • hanger10
        • Sep 2008
        • 102
        #63
        shims
        Phil, I went to http://www.crc2onlinecatalog.com/Index_Main_Frame.htm, found the right idle jets, but need to know the size on the main jets, Im gonna get them too. And, I would also like to get new fuel mixture screws, but havent been able to find them on that site, anyone know where I can get just the fuel mixture screw???? Now, we used the method of making a small tool out of an allen wrench, putting it in the slot and rotating the cam. We got clearance to get the shim out, but we cant find a damn magnet with any power to get them out!!!!!! Does anyone have any tricks to get around using the magnet???? We have tried tweezers, and no luck. Thanx for the patience and help guys, I know Im a pain in the ass!!!!!!
        PS- As for main jet size, I would like to get everything back to stock, dont want anything for more power, etc!!!
          There is a notch in the side of the shim bucket, rotate it facing you before compressing the valve. Pop it loose with a small screwdriver, then use the magnet. JMHO, not necessary to replace all parts in your carbs unless they are worn or broken, it can become expensive.
          • hanger10
            • Sep 2008
            • 102
            #65
            shims
            Thanx bro, but we cant find a magnet that will work!!!
              You really need to be careful if you use a magnet on valve shims. If the shims get magnetized they try to 'stick' to the cam and wear down the lobes.
                #67
                I just wrapped this up on my engine (valve shims). What I do is to take the base for my dial indicator, similar to the one shown HERE with the green label on it, and turn it on with a small size screw driver on it, this magnatizes the screw driver and then I use it to pull the shim out.
                • hanger10
                  • Sep 2008
                  • 102
                  #68
                  Shims removed!!!!
                  Ok, we finally gotem out!!! And, without a magnet!!! Im in the Philippines, and we COULD NOT find a decent small magnet to get them out. My buddy made a tool out of an allen wrench to use in the slot to hold the valves down. Here is the pic
                  http://www.flickr.com/photos/5605326...in/photostream
                  He took two disposable razors, cut off the heads, ground them a bit, and used super glue to get the shims out! Just used the super glue on the ends of the handles and glued to the shims. Heres the pics
                  We did the measurements in thousandths. Now, we did the conversions to MM, but wanted a few of you all to tell us if we are right or wrong pleas.
                  Exhaust valve lash- .007
                  Old shim number 290
                  after conversion, we figured a number we needed 285
                  Intake valve lash- .0015
                  Old shim number 280
                  after conversion, we figured we need a number 265
                  Please check and see that we got the right shim that we need! We are getting there, slowly but surely!!! Thanx millions!!!!
                  Randy
                  • Steptoe
                    • 175
                    • Thabeban,Bundaberg QLD , Australia
                    #69
                    shim tool
                    here you go hanger,, knocked this up in an afternoon,, sorry bout the sidewaysness
                    here's a photo step by step,, there is descriptive text on each pic,, hit slide show button
                    got a tool to keep then
                    keep workin on it,, you'll end up getting it
                    never ride faster than your gaurdian angel
                    can fly
                    1981 rh 5N5
                    MIDNIGHTSPECIAL
                    1188cc
                    4 into 1 pipes with a transac muffler,
                    as the motorcycling gods intended everything else stock std
                    http://s856.photobucket.com/home/steptoexs11
                    http://steptoexs11.webs.com/
                    http://www.youtube.com/my_videos?feature=mhum
                    1982 vf750 sabre
                      #70
                      Did you only check one valve?
                      • hanger10
                        • Sep 2008
                        • 102
                        #71
                        valves
                        checked all valves, and posted the lashes in previous post, only two needed shimming!
                          #72
                          Old shim number 290
                          Old shim number 280
                          Randy
                          That should be perfect....
                          Each shim change is worth .0019" difference in clearance, so that would make your exhaust .009" (right in the muddle of the spec; good to go) and the intake .007" (ditto)...
                          • hanger10
                            • Sep 2008
                            • 102
                            #73
                            Shims done!!
                            Ok guys, the shims were replaced today. Wont know if this fixes the miss until next Sunday, coz we have to make a gasket for the valve cover, and my buddy that does it cant be here till then. But, here were the lashes before replacing shims:
                            intake-.0015
                            exhaust-.007
                            After replacement:
                            intake-.006
                            exhaust-.009
                            The exhaust is dead in the middle, and Crazy Steve, I know the intake is on the low end, and should have been .007 after replacement. My friend that pulled the shims also put em back in this morning, and he made completely sure they were clean, and he says we might gain .001 on the intake lash, coz there may be a little oil keeping the shim from setting in perfectly. Ive got my fingers crossed, will find out next Sunday, and will let ya know. Thanks again so much for all the help everybody!!! Take care, and mabuhay from Liloan, Cebu, Philippines.
                            Randy
                            PS-Also, my friend just told me that the intake measurent was a loose .006, and that we didnt have a .0005 guage!!!!
                              #74
                              Hope things work well! Glad you are making progress!
