I've been trying to find an original set of pipes & mufflers for my XJ11 with only moderate success. I've been able to find a pair of XJ11 mufflers for it that are missing the crossover pipes. I figure I can get that repaired at a welding shop. It still though needs the headers.
I've looked at the cross references for the pipes and I'm finding the XJ11 is only partly interchangeable with the XS11 parts. Here's what I've found so far & I'll finish my question after the "facts":
Data from: http://www.yamaha-motor.com/sport/parts/home.aspx
Right side outer pipe (10M-14625-00-00) only fits the XJ11
Right side inner pipe (2H7-14631-02-00) is the same for:
XJ1100J 1982 1100 XJ1100 Street
XS1100E 1978 1100 XS1100 Street
XS1100F 1979 1100 XS1100 Street
XS1100G 1980 1100 XS1100 Street
XS1100H 1981 1100 XS1100 Street
XS1100SF 1979 1100 XS1100S Street
XS1100SG 1980 1100 XS1100S Street
XS1100SH 1981 1100 XS1100S Street
Left side inner pipe (2H7-14621-02-00) is the same for:
Left outer pipe (10M-14615-00-00) is the same for:
So I continue...
The parts diagram does not give dimensions or the reasons for the variations. Looking at photos of different XS11 & the XJ11, they look to be the same except for the appearance of the mufflers. All the headers pass around the frame in the same way and since the engines are pretty much the same except for the XJ11 YICS passages & some ignition differences, the physical engine plant looks to be the same. Since all the engines are designed to work with the BS34 carbs and the restriction characteristics of the Yamaha muffler, I have a few things to ponder to know what might be easily possible.
I wonder if the differences in the headers comes down to aesthetics? Perhaps the headers are really the same but with a different flange or some minor cosmetic issue and any of the XS11 headers would work?
Also by that same thought, it seems like the mufflers would be the same restriction wise and perhaps all that's needed is a different bracket or a minor bend and any would work?
At this point in time I haven't seen much original exhaust offered for the XJ11 & while I'd like to have the original parts on it, I'm not going to be showing this bike and if something's not 100% XJ11 but works perfectly and looks clean, I'm happy.
So what's the differences in the headers and pipes that make interchanging parts a negative other than loss of originality?
Idears?
So I continue...
Idears?
