Does anyone know someone who can reajust my carbs for a reasonable price without burning a hole in my pocket?
Carb Rebuild or reajust?
What part of VA do ya live in? I happen to live in northern va. Ashburn/Dulles area. I can sure fix carbs1978 Macho Maroon XS1100 Mikesxs green coils, ZRX Carbs, spaghetti jardine 4 into 2
1989 FXLR harley that is not stock
1977 RD400 stage 2 ported with VM30 carbs
1975 RD350 modified
I can't leave anything alone -
Can't be final adjusted off the bike, they have to be installed and running on your bike.
Where in northern PA are you? I do get out that way and plan to be in Monroe county on April 2nd.Former owner, but I have NO PARTS LEFT!Comment
These carbs are fairly cut and dry simple. So consider giving it a try.
As stated though, a bench synch and setting the screws so many turns out is just a point to let the bike start and run decent so the tuning can be done.Life is what happens while your planning everything else!
78 XS750Comment
Hey, I live in Monroe county PA, I am no expert but We might be able to get them working.Trying not to offend since Aug 28, 2010
Disclaimer: I am an idiot. Pay no attention to the man behind the curtain.
Owner of:
1979 XS1100F (The Pig)
140 mains
45 pilot jets
Floats at 24mm
Running Rich
"Arrogant, delusional tyrants can't be stopped by earnest words and furrowed brows. Action, strong bold action coming from a position of strength and determination, is the only effective deterrent." -Mitt RomneyComment
I've already done a crude sync... the paperclip sync... worked for a while... but now i have gas pooring out of my air box... Pretty sure the floats need to be re adjusted, the needle jets adjusted... Not to mention to get it to start i have to blow into my tank to pressurize it to start... after that it will run all day long...
I took them out to clean them cuz they where getting gummed up... my #1 cylinder runs cold #2 is very hot #3 is hot and #4 is hot... I'm in Clumbia county not that far really... i can get the bike to run but i have to do a title transfer from when i was living in VA... so getting the bike to you in monroe might be a slight issue... but i do have my ways...
Took the float bowls off to polish them i may have bumper the floats...Comment
Columbia county... Berwick... i can pull the bank out and redo the sync... possibly ajust the needle jets... but not sure how to ajust the floats...Comment
The key to setting it up right is to have the carbs and the bike in the same place at the same time. I have all the tools to set it up right, if we can work out the meet-up on April 2, I'm in. I have to be finished by 5PM,though. Let us know.Former owner, but I have NO PARTS LEFT!Comment
