Is this the CCT I shoud be looking for?
  • jwhughes3
    • 2798
    • Home of the Alamo
    It says 83 Venture 1200 which sounds right but I've never seen one so I just want to check before pulling trigger.
    Thanks
    John
    '81 XS1100H - "Enterprise"
    That's the one.... bit pricey though.
    • jwhughes3
      • 2798
      • Home of the Alamo
      how much should it be?
      I haven't seen them on there..
      John
      • Iron Duke
        • Jun 2010
        • 74
        • Manhattan,Ks
        Cct
        Just put one on Looked just like it ,just like it, its plug n play all the way Steve's right little pricy mine was 9 cheaper with S & H and a lot cleaner and newer looking.
          See they are a bit harder to come by used, but a year ago new they listed for $186 and change. With import cost going up substantually late last year, sure the cost is substantually more new.
            Believe it or not I think Ivan stumbling on this mod made the cost of them skyrocket. When he first posted the mod, you could pick one up for about $10 + shipping ..maybe $5. I am pretty sure I got mine for $15 total. Some folks got two for $20 or maybe $30. Then in a month or so, the price was up to $50 for one. Now it seems to have settled out a little.
            Law of supply and demand at work!
              And with the the fecal matter that hit the rotary impeller over there in the last week, the price on that stuff new is likely to go even higher and get even harder to get. And those unobtainium bearings, may become even more so. I'm unsure what the events in Japan are going to bode for parts availability for older Japanese bikes over the next couple of years.
              • jwhughes3
                • 2798
                • Home of the Alamo
                OK cy you convinced me...
                Decided to bite the bullet and not let $15 stop me from making a good upgrade.
                Thanks
                John
                • Rasputin
                  • 3189
                  • Lacombe, Alberta, Canada
                  After the first swap I did, I decided these were the way to go. I only have 2 so far but need a few more....about 5... I would pay the difference if I was in a hurry but the stockers work just fine so I am in a wait a and see what comes around type mode. There are not that many XSers that even know about this swap when you think about it so I do not think we have driven the price up by much. Some hell yeah but not much overall. I will not bid on those just because they are a bit higher than I want to pay. Just my opinion.
                  2-79 XS1100 SF
                  2-78 XS1100 E Best bike Ever
                    I have said it before and I will continue to say it. The yamaha vision 550 tensioner fits with just about 2 swipes of a round file. I paid 6 bucks for it shipped.
                      Nate's choice another good option. From personnel experience myself having had the original style adjuster slip back while starting and not realizing it until under way when the motor sounded like a hay-bailer, I would'nt use a stock adjuster on a bet. Design is obviously the first flaw. The retainer bolt isn't an actual "set" bolt for this type of application. A long actual allen head type set screw is actually what's needed. Taking one completely apart and seeing all the set marks, some overlapping the previous I realized that over the years with the several set marks, what I believe is happening is when pressure comes against the adjuster shaft it WILL "walk" back to previous set mark. I believe this happens a bit easier if the adjustment only allows the shaft to move half the previous set mark. A temporary remedy to this, and could save some valves and a lot of expense if continueing to use the stock adjuster would be to file the flat portion of shaft back smooth before re-using. Have seen this happen on a number of occasions in large equip. applications using large self-centering bearings that get replaced on a regular bases. Hot plants, screening plants and shakers come to mind. These are excessive applications, but all realative to the same result over repeated marks being left on shaft. JAT based on my long time experience with this type of set-screw application and what happens when directional load/force is applied to what it supposed to hold stationary. Either way, IMHO a self locking/racheting type cam chain adjuster could make your day riding more enjoyable and save any (if your fortunate) top-end damage.
                        Angle grinder
                        Put a taper on the adjuster so it can only move in toward the cam chain and can't back out unless the set screw is loosened.
                        • cowboybob998
                          • Mar 2009
                          • 371
                          • KC MO
                          Cct
                          That Auto CCT that is in the venture is just not in the old Venture, somewhere on here i reasearhed how many years used this same CCT and did a post of that, see if i can find it and repost it.
                          83 to 2010 venture all has the same CCT
                          1979 xs1100 f
                          142 main, 45 pilot, Jardeen crosover 4/2, no air box
                          floats @ 25.7
                          1979 xs1100 F
                          1978 gl 1000 goldwing
                          1981 gl 1100 goldwing
                          !986 venture royale 1300
                          Just an ol long haired country boy, come to town to spend some egg money
                          when ya get bucked off, get back on
                          • yamahansolo
                            • Aug 2007
                            • 1113
                            • jawga
                            Don't forget the vmax tensioner is the same part numbee from yamaha. I bought 2 dor 30 bucks a couple years ago. The vmax guys may not realize. We can use them.
                            Her is one for 39.95 my two looked better though. They were from either. An 06 or 96 I can't remember now...
                            79 xs11 standard
                            8mm msd wires
                            tkat fork brace...
                            Fox shocks...
                            mikes650 front fender
                            led's gallore...
                            renthal bars
                            gold valve emulators
                            vmax tensioner
                            Rifle fairing
                              • 8799
                              Those VMax tensioners are nice, I have one on my 79SF. As for the stock XS11 tensioner I have on my 79F, I took the plunger out and tapped the center hole with a 3/8" tap (no drilling required) as far back as the hold down bolt. Retaining the plunger, now a 3/8" bolt can be threaded in there with a lock nut as a stop. No possible way for it to slip now. Put some RTV on the threads so it won't seep oil, just have to be careful not to over tighten. This works great until I find another $5 VMax tensioner.
